I see.
I've been working on the bike almost everyday for about 3 months, and I can't exactly recall everything I did in perfect orders
![Sad :(](http://forums.sohc4.net/Smileys/default/sad.gif)
But what I remember is, I replaced the entire electrical harness with LED lights, replaced condensers, then replaced petcock.
Shortly after, bike ran like crap, did valve lash, points&timing, then eventually found that all 4 main jets had dropped to the bowl!
I put them back on tight, ran good for a few days, and the problem began.
I looked at everything again, found cracks in the main jet post, on carb #1 and #4, probably due to over-tightnening it.
I wasn't sure how long it had been like that, but I sent the carbs for laser-welding, the crack is completely sealed now.
I pulled the carbs out and soaked them in carb cleaner, blew air and thin wires through passages.
The emulsion tube was a little bent, so I hammered it straight and put it in #1 carb.
I checked and all the needles seem straight, and I can't find any flaws in the carbs, except for the weird float height problem.
Since #2 plug is black, I don't think the crack had anything to do with the problem though...
