Author Topic: Loose rubber o-ring thing - what is it for?  (Read 4879 times)
Offline MoMo
  • Ride like you're invisible
Re: Loose rubber o-ring thing - what is it for?
« Reply #25 on: July 26, 2018, 04:16:40 AM »
6 x 1.0 is std.  thread insert and helicoil are not he same thing.. Good luck
Offline 01Thomas
« Reply #26 on: July 26, 2018, 01:56:08 PM »
As some others here have pointed out, there is no need for locktite on any of these screws. But steel screws in an alluminium casing will undergo a galvanic reaction over time and chemically bond to the alluminim. To avoid this, if you're not using locktite, do use an anti-seize paste on the threads, on all bikes, everytime.
BTW, what the Original Poster is calling the clutch cover is actually the Transmission selector cover. The propper Clutch cover is on the other side of the engine.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
