Author Topic: Cb350f weird ignition timing issue  (Read 852 times)
Offline Biebs
« on: June 15, 2018, 06:35:15 PM »
Bike will not fire Checked with test light point static timing blue wire for 1/4 points comes on when at the 2/3 mark and yellow wire 2/3 mark light comes on at 1/4 mark.
So it is backwards bike will not fire any words of wisdom from the group.
Had it running 4 days ago this is right after a top end rebuild first time I have checked the points / static timing - am I doing something wrong??
Phoenix AZ
1991 CB750 NightHawk
1973 CB350F
Offline innovativems
    • Innovative MotoSports
Re: Cb350f weird ignition timing issue
« Reply #1 on: June 15, 2018, 07:44:14 PM »
Sounds like your points leads are swapped.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #2 on: June 15, 2018, 09:38:37 PM »
It sounds like your spark advancer cam is 180 out of phase. Did you take it off? It's easy to put back on backward. There's an indicator notch on the top edge of the cam that points to a unique mark (often a hole) on the baseplate, to point it in the right direction, so to speak.
Offline Biebs
« Reply #3 on: June 17, 2018, 06:07:51 AM »
I believe what happened is after my top end rebuild and in haste to get it started, I forgot to tighten the cam chain tensioner.  Seems I have jumped some teeth on the cam chain - just a guess.  Sound probable???
Live and Learn - but at my age I should have all the wisdom!!!  Damm!!!
 :'( :- :o >:(
Phoenix AZ
1973 CB350F
Offline robvangulik
  • Honda Fourever
« Reply #4 on: June 17, 2018, 11:11:54 AM »
 :'( :- :o >:(
No.
Do as Hondaman suggests!
Offline Deltarider
« Reply #5 on: June 17, 2018, 11:26:35 AM »
 :'( :- :o >:(
No.
I'd start with checking the leads are connected correctly though.
CB500K2-ED Excel black
Offline Biebs
« Reply #6 on: June 17, 2018, 11:32:42 AM »
Never removed the spark advancer cam - not to worry I fixed it new owner picked it up today.  Rode 60 miles this morning on my DOHC 750 NightHawk.
Life is good.
Phoenix AZ
1973 CB350F
