So my battery wasn't charging and my mechanic tested the voltage regulator finding it was non-functional. Strangely, I had to finish a 300 mile ride with the headlight off. He replaced it with a rectifier, and all seemed well. We then changed out the OEM headlight, with a modern H4, and I soon had some problems. Namely, the left turn signal wouldn't work unless I got up and held rpm's at about 3000, and the battery would slowly drain.
I put a new gel battery in, and it was great for the first 20 miles and then all the symptoms came back. Replaced the bulb itself, I think to a 55W, and the problems just continued. Out of frustration, I put the original sealed beam headlight back in (I think it said 35/40W on the bulb itself). Fixed everything...weak spark, etc etc. Everything works great again. I thought I once read in the original Honda literature to never replace the bulb with anything else as the electronics were not designed to handle it. The headlight, like it's owner, may not be the brightest bulb in the box, but it works. My concern is if it ever burns out, are there sealed beams of OEM ratings still available? any other thoughts?
