Author Topic: 71 CB450 No headlight or rear running light  (Read 1214 times)
Offline rymian
« on: June 19, 2018, 04:17:51 PM »
Recently purchased a 71 CB450 knowing full well that the headlight and taillight were not working. I am new to motorcycles especially something this old. I know that a lot of the connections are housed inside the headlight housing. Should I start there for checking connections?
Online calj737
  • I refuse...
Re: 71 CB450 No headlight or rear running light
« Reply #1 on: June 19, 2018, 04:52:01 PM »
Use a meter. Test the actual wiring at the component with the key ON. Do you have 12v? If not, time to start deeper diagnosis.
Offline Scott S
« Reply #2 on: June 19, 2018, 05:09:29 PM »
 Check the easy stuff first....the bulbs.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: June 19, 2018, 08:34:29 PM »
Are both high and low out? tail and brake light out?  Welcome and congratulations on buying"the most impressive Honda ever made".   ....Larry
Offline tbpmusic
« Reply #4 on: June 20, 2018, 01:42:58 PM »
Yuk, yuk - I never get tired of that......
Bill Lane
Offline MoMo
« Reply #5 on: June 20, 2018, 07:41:04 PM »
me either, it is about as farcical as it gets.  However, the 450 was an extraordinarily innovative motor design
Offline rymian
« Reply #6 on: June 21, 2018, 06:39:28 AM »
Worked through some things last night and got the running taillight working along with the brake light. Simply a loose connection inside the headlamp housing. This also got the tachometer back light to start working. Lowbeam, highbeam, highbeam indicator light and speedometer light all still not working. Couldn't locate any other loose connections inside the headlamp housing.
Offline MoMo
« Reply #7 on: June 21, 2018, 09:34:34 AM »
Does the 71 have an on/off switch for the lights?  Also, check fuses if you haven't
Offline rymian
« Reply #8 on: June 21, 2018, 01:59:34 PM »
Yes it does have an on/off switch and it works because the running taillight turns on and off with it. Only has one fuse and it is getting power on both sides of the fuse.
