SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Cb750 head dowel and oring placement issues
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Cb750 head dowel and oring placement issues (Read 587 times)
Knightro
Maker hack in Manitoba
Full Member
on:
June 23, 2018, 03:21:27 PM »
Hey folks. Not sure why but my hole for the #8 pin dowel in my cb750 doesnt fit and i dont want to hammer it. Why this no fit. Ibelieve this is the same dowel as goes under the cylinders as well.
Also... #15 o ring. Is this where they go? See photo. Bottom right in photo
Logged
1982 920 Virago.... long sold
1982 cb900f. In progress
1978 GS750
1978 CB750K
1978 cb550
"If it aint broke don't fix it!" but if it's working, take it apart so when it is broke, you know what your doing... we'll see how much $ this theory will cost me. lol
754
Really Old Timer ...
Re: Cb750 head dowel and oring placement issues
Reply #1 on:
June 23, 2018, 07:53:48 PM »
You may have mismatched parts. What year head and cylinder do you think you have?
15 and the piece under it, are in top right of your second pic. Be careful air blast can pull them out and lose them. When you remove the rocker stand remove these and clean the oil passage. There is 2.
Last Edit: June 23, 2018, 08:03:53 PM by 754
Logged
Kelowna B.C. Canada
Jerry Rxman Griffin aka MuthaF'er
This MuthaF'er is getting to be a
Bought her new 4/75
Reply #2 on:
June 24, 2018, 09:28:35 AM »
You have 2 different length dowels for the cylinders top and bottom. Get them in the right positions.
Logged
As of today 3/13/2012 my original owner 75 CB750F has made it through 3 wives, er EX-wives. Free at last. ;-)
754
Reply #3 on:
June 24, 2018, 09:33:14 AM »
Sometimes dowels get damaged while pulling them, like scratches or out of round.
You have to clean it up to reuse them, or replace them.
My preferred method of removal, run a tap into them till they start to turn, then turn and pull.
Logged
Kelowna B.C. Canada
Knightro
Full Member
Reply #4 on:
June 25, 2018, 11:54:06 AM »
Thanks guys,
Turns out there were some burs and a little cleaning and scrubbing got it sorted out with a little finesse.
Thanks for the help.
Logged
1978 GS750
1978 CB750K
1978 cb550
PeWe
Bike almost back to the 70's 2015
Reply #5 on:
June 25, 2018, 01:00:58 PM »
Measure depths on both sides just for sure. Machined cyl, head will need a shorter dowel. if not the head or cylinder will not tighten properly. You need a vernĂer caliper
My setup cannot use 18mm dowels at the corners for head, 15mm last time or the special ones 14.5mm (that were used with late head and stock gaskets 8 dowels)
Bottom for case-cylinder were 22mm once for my stock k6 cyl. Measure the holes since 18mm might be max.
I used 15mm since 18mm was just too long if I remember correctly at my last build.
Logged
CB750 K6-76 970cc (Earlier 1005cc JMR Billet block on the shelf waiting for a comeback)
CB750 K2 -1975 build thread
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
