Carb swap is not moving forward with tuning. Put a set of 627B carbs on a cb550 (manifolds back). Carbs are super clean, floats set, manifolds sealed up, synced bench and on bike (although rich), all the boxes checked. Started with 45 pilots (genuine Keihin) and was real rich at idle - black smoke burn your eyes rich. Moved to 40 Keihin which would be stock 627B on a 500, still real rich, but a little better. The pilot air screws do not seem to impact fueling at all. I have flushed this circuit 3 times to make sure it wasn't clogged/trash. They are definitely aftermarket screws. Wondering if this is more of the problem before I drop pilot jets again. I can only find Keihin to 38, and aftermarket down to 35. I don't believe either of those will be lean enough, and doesn't seem right anyway - I expected to be lean when I was testing with an open header and no filters. I was running great with a 42 pilot on PD carbs on the same bike. Doing the swap for cosmetic purposes. Is this a fault of crappy aftermarket pilot air screws or am I missing something else?
