The 750F (and 550F) uses the same ignition as 77-78 750K. On my 750F I had to replace the ignition not because there was an issue with the prongs, but because there was excess wear on the contacts on the inside of that part of the switch.
If you separate the plastic housing (carefully, you don't want to break anything and have no choice but to replace it), inside are 2 clips, 2 small ball bearings, and 2 very small springs that fit inside a round plastic disk. The disk has contacts in it that extend through the disk and attach to the prongs.
On my 750 the small contact points on the inside of the disk had worn and the clips that connect the contacts and distribute the power didn't make a good connection.
You can inspect the switch or decide it isn't worth the effort and buy another. 4into1.com sells a switch/seat lock combo for about $40 that uses a revised switch with the prongs in a connector housing connected to the switch by a pigtail, so it makes it easier to plug in and also insulates the connection from the vibrations that cause the original switches to stop working.
