Author Topic: 1974 CB750 Rod Weight for Rebuild  (Read 772 times)
Offline pstoltz89
« on: June 29, 2018, 06:20:27 PM »
I am rebuilding my 1974 CB750 and I have two sets of stock rods, but only 5 of the 8 rods are in usable condition .  I weighed the rods I want to use and found that two are 386 grams and two are 380 grams.  My question is can I use them as they are?  Or do I need rods that are closer in weight?  Can I shave some material off of the heavier rods to get them closer to 380 grams?  This is not a performance build.
Thanks in advance for the advice.
« Last Edit: June 30, 2018, 07:59:11 PM by pstoltz89 »
Offline Yoshimatic
  • The Stable
Re: 1974 CB750 Rod Weight for Rebuild
« Reply #1 on: July 13, 2018, 06:50:03 AM »
I thought the rods had a letter printed on them like a H,J,K etc. these letters represented the weight of them. You should really have all the same weight rods if you want it balanced and smooth.
1969 GL175 twin
1970 CB750 K0
1971 CL350
1975 CB750F1
1977 CB750F2
1977 CB750A (original condition)
1977 CB750A (836 Cafe Racer)
1978 CB750F3
Offline Yoshimatic
  • The Stable
« Reply #2 on: July 13, 2018, 07:15:38 AM »
This chart explains the rod weight marking.
1969 GL175 twin
1970 CB750 K0
1971 CL350
1975 CB750F1
1977 CB750F2
1978 CB750F3
« Reply #3 on: July 13, 2018, 12:31:47 PM »
Can't say that I ever weighed the same lettered rods as I've just matched rods by that weight letter designation. That being said you could always grind off a little weight to exactly match them.
