Author Topic: 79 CB650PZ - Frame questions  (Read 426 times)
Offline lukemillar
« on: June 30, 2018, 05:25:43 PM »
Hey all,
First post here! A wee bit of background.... I bought a 79 CB650PZ from a friend who took it apart to build a cafe racer out of it and never got any further! It is in very bad state, with multiple (bad) re-sprays and half the parts missing. I bought it to use as a donor bike for a electric motorcycle build. Don't hate me at this point - it is something I find interesting and I have built and tuned many combustion engines/racebikes so I fancied doing something different here. Cafe racer CB's are ten a penny.
So far I have hit the easy stuff, rebuilt the forks, brakes and sourcing a spoked front wheel. I found a new product which is a spoked rear with a hub motor built into it which will service the back and it also allows me to ditch the large drum brake in favour of a disc. Nice.
The next main job on the list is to start going over the frame and I have a couple of questions. First is a broken rear shock mount:
It is only the stud that has snapped off, the mount itself is ok. These parts don't look serviceable as they are welded into the frame. Has anyone come across this before and how have they tackled it? I was going to just drill out the stud, tap it to the next size up and just use a larger nut to retain the shock.
Also, looking at the engine mounts on the frame, their appears to be a section of frame the is bolted on on the right side. It is pretty much one side of the engine cradle. Is this there to allow the engine to be removed? Since I don't need an engine anymore, I was wondering if I can lose the mount and just weld the section in place (similar to the LHS) but I want to confirm the purpose of the removable section first.
Any insight into these two things would be great!
Thanks
Luke
Offline American Locomotive
    • sohc4
Re: 79 CB650PZ - Frame questions
« Reply #1 on: June 30, 2018, 09:29:13 PM »
You can drill and tap the shock mount for the same bolt as that stud, no need to go bigger. I really wouldn't want to go any bigger anyways, to avoid compromising the strength of the shock mount.
Offline lukemillar
« Reply #2 on: June 30, 2018, 11:11:12 PM »
Ah sweet - that is even better.
Offline jaytee-nz
« Reply #3 on: July 01, 2018, 01:27:42 AM »
Hi Luke - JT here from New Plymouth.
You are correct in that the mounts are designed for the engine to be removed from one side so if you don't need the mount anymore it won't be an issue to remove it.
Good luck with the project.
