Thanks guys, that's great news!
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
Ive pulled most of the them apart now, wasn't too difficult when using Brain Barnes' fantastic guide (the link from this forum to that is dead by the way). Ive got a couple of questions though:
- His guide mentions that each pilot jet should have a spring, washer and o-ring. None of mine had the washer, there was only the spring and then the o-ring. How important is the washer? Should I look for replacements?
- The choke shaft has felt seals which I can get from dudesgarage.com, however the throttle shaft has a combination of some being felt, some being rubber o-ring and some had nothing! Again I can get replacement felt seals, but is there any source of replacement o-rings?
- What is the correct combination of felt and rubber seals?
This guide says "on carbs #1 and #4 these seals are made of felt. On #2 and #3 they are rubber", is that correct as mine had rubber on carb #1 and I have some that are missing. Just want to make sure I get the seals correct.
