We had over 32C (90F) today (again) which is warm for Sweden. Thick leathers felt fine. I can cope with it better now since I have lost some of the overweight. Oil temp 120C after some twisting with old biker friends from the first half of the 80's.
Thanks to this thread I searched more among Porsche threads I have seen discussed oil quality vs high engine temp and air cooled engines before. The link in my previous post made me to think.....a little bit extra....
I think I have solved my old mystery when I blew a piston, the piston beside going to get a hole too when it had a dent. Photo in previous post.
It must have been the oil. Oil and ambient temperature + raised engine temperature due to higher CR have a relation.
I do not remember which oil I used, but it must have been too thin relative the temperature and lost the pressure, wrist pins in contact with rods small ends running hotter making rods bluish and engine even hotter pistons included. Either wrong oil (too thin) or it was worn out, lost all additives making it to a 50 oil from a base 20. When this happen the oil is a plain base oil of viscosity 20 and metals will connect since the pressure will be lost, not enough oil film between the metals.
Single grade Quaker State from Pennsylvania with the best base oil molecules in the world (extra long) was popular back then. Or Vance & Hines oil. Quaker State might have been thinner than single 50.
I know it happened after my long touring, It must have got refill along the road but might have got wrong type or just crashed oil viscosity.
It comes to the oil again even if that is seen as popcorn for many.
I'll put 20W-60 synth oil in my 120C (248F) oil tank bike!
It is not the high ambient temperature that kills the engines if happen, It's the oil that is not good enough for that high temperature.
