Hi y'all! I'm Jessamine.
![Kiss :-*](http://forums.sohc4.net/Smileys/default/kiss.gif)
I'm new here and currently rocking a KLR and a Helix, but would love to join the club!
Found what might be a great deal (or might be a terrible mistake) on the local Craigslist this week, and went to check out the bike in person the same day; it's a 1975 CB750F with a clean title. Asking price was $900, and I talked him down to $600+Delivery to my workshop (which is swell 'cause I only ride two wheels).
Current and PO made a few questionable choices (like trading the stock airbox for pods
![Sad :(](http://forums.sohc4.net/Smileys/default/sad.gif)
), but overall the bike looks in decent shape. Current owner is a "bolt-on" kind of guy (little to no skill with diagnosing or repairing internals, but can swap the farkles well enough); new tires, rebuilt shocks, new gauges, new bars, good brakes, etc. Looks like everything on the bike is in great shape-- except one big problem:
He says he took the bike into a local shop for a new head gasket and a valve adjustment, rode it home, then spent a few months swapping parts before his next ride. On that ride, he says he was cruising along and the engine suddenly died with a single clunk sound and hasn't started since. His best guess is a snapped cam chain, but he doesn't know and doesn't want to spend the money to find out. My limited examination of the engine would seem in line with his guess: I feel no noticeable compression at the spark plug holes, can't see any valve movement in cylinder when moving the starter gear with the kickstarter, electrical seems well done-- though carb#1 is leaking some gas from the overflow port when the starter is engaged so there may be a simple fuel delivery issue at fault.
I've done a full rebuild on a CB350-Four and fixed many other things on 70s-90s Hondas, and I'm a pretty capable mechanic all around, so I feel confident I could do whatever it needs, up to splitting the cases if I absolutely have to. Question is how risky of a buy is this? Any alternative theories? I'm not sure how much interference the valves on these bikes have with the pistons-- would a snapped cam chain definitely result in damaged valves? If I'm crafty enough and the chain did snap, could I sneak a new one with a master link over both sprockets without splitting the cases and working it over the crankshaft? I've got this vision in my head of using an extending magnet and long reach tools to thread a new chain end thru the tensioner, around the crankshaft, and back up from the abyss-- but maybe that's pure fantasy.
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
It'd be swell if it had just hopped the sprocket and was hanging loose on the camshaft because the shop forgot to reinstall the tensioner properly
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
What do y'all think? Worth taking a chance on it for a project bike, or am I setting myself up for sorrow/an engine swap?
