Author Topic: Tie down straps - bad idea?  (Read 1897 times)
Offline eigenvector
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Tie down straps - bad idea?
« Reply #1 on: July 06, 2018, 10:35:08 PM »
Your last sentence confuses me.. just what do you think they are made of ?
Not a useable spot to tie down in the pic btw.
Offline 74cb750
« Reply #2 on: July 07, 2018, 01:51:41 AM »
also looks like the tie-down goes Over the fender. Gee, wonder if it will bend the fender.
Laugh at least once a day.
Life  $ucks, then you die.
« Reply #3 on: July 07, 2018, 02:23:36 AM »
look like much of a muchness to me?so hooks are the weakest link,#$%* ive never had any strap or hook fail/bend/break or loose its colour?
Online spotty
« Reply #4 on: July 07, 2018, 02:59:46 AM »
Just make sure there's someone holding on to the bike when you undo the first one at the other end of the trip.....
i blame Terry
Offline eigenvector
« Reply #5 on: July 07, 2018, 09:16:22 AM »
You guys seem to be okay with the idea - fine I won't argue it.
Personally I wouldn't attach anything to the fork tubes.  Besides, having the strap that low on the bike doesn't gain you much anyway in the way of leverage, which I think you noted Frank.
Rob
1977 CB550K
1983 VF750S Sabre
Offline cb650
« Reply #6 on: July 07, 2018, 09:34:14 AM »
I usually go to the lower triple tree.
Offline slikwilli420
  • Master of Disaster
« Reply #7 on: July 07, 2018, 03:40:08 PM »
How in the hell do you tie a bike down then? Thousands of miles with straps at the lower triple on the forks with no issue.
« Reply #8 on: July 07, 2018, 06:43:40 PM »
Never put a bike on its center stand when trailering either.
Offline eigenvector
« Reply #9 on: July 10, 2018, 04:20:31 PM »
Part of this for me is forgetting that not everyone has the same trailer layout.
It really didn't occur to me until I thought about the responses some more.
All my D-rings are at the far corners.  Putting straps on the forks would just simply not work - and again I personally think it would too much stress on the fork tubes (that's just the engineer in me).  The straps on the fork tubes would be too low to provide much leverage, which is why I use the bars.  If the D-rings were close in, of course putting the straps on the forks would be a better solution.
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #10 on: July 10, 2018, 04:43:43 PM »
 Again what part of the forks are you talking about, we have no clue.
 Disregard the photo at the beginning, not a recommended spot to tie down.
Offline eigenvector
« Reply #11 on: July 10, 2018, 04:57:07 PM »
That's exactly what I'm talking about.  I've seen more than one picture with that very spot used.  I'm guessing because people use the wheel chock tie down spots and short straps made specifically for that.
But any location on the actual fork doesn't make sense to me.  Use the fork brace if it has one - sure, nice rugged structure, use the triple clamp if you can get to it.
Rob
1977 CB550K
1983 VF750S Sabre
Online spotty
« Reply #12 on: July 10, 2018, 05:18:45 PM »
i don't use the handlebars, tried this once and as i ratcheted the straps down i watched the handlebars bend in response ( and no i didn't attach the straps to the grip area, they were attached either side of the bar clamp area, still bent them though) , used the lower triple clamp and no problems, same when i tie down the bike on the bike lift, clamp the front wheel and then tie down from the lower triples
i blame Terry
« Reply #13 on: July 10, 2018, 05:37:34 PM »
As I said picture was a joke.
 By tying down off forks, to most people that means lower triple tree, or higher.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #14 on: July 10, 2018, 07:57:41 PM »
Damn, I always though trailers were for boats.
« Reply #15 on: July 10, 2018, 10:24:03 PM »
 I bought 6 750's and a gl1000 none of which ran. Hard to get home with no trailer. I use ancra brand straps and soft ties. My choice of tie down points depends on the bike and situation. I had a nice looking heavy size farm store strap snap once and I almost lost a cb900c over the side of a trailer.
« Reply #16 on: July 10, 2018, 11:41:28 PM »
I think you mean fork leg, the part that holds the wheel, and rides up and down the Fork Tubes.
Offline eigenvector
« Reply #17 on: July 11, 2018, 07:37:26 PM »
Yeah, you got it.
Suppose it makes a difference if we're all speaking the same language.   ;)
Rob
1977 CB550K
1983 VF750S Sabre
Offline eigenvector
« Reply #18 on: July 11, 2018, 07:40:52 PM »
Yeah I know the feeling.  My buddy had the lift off the truck bed on his F-100 - used harbor freight straps (Doh!) to keep it airborne until he could get blocks under it.
<RIP!!!> ( as in rip/tear - not rest in peace ;D) while it was swinging.  I never buy anything related to safety from a discount store.
Rob
1977 CB550K
1983 VF750S Sabre
