Sure it was not there before? I have bad dowels that will follow the cover when lifting it and jump off right over the rocker arms. I'm sure those small bastards aim to the cam chain tunnel. I lift cover a up and forwards and check where I have them before lifting off the cover completely which will be backwards + sideways since I have engine in frame and frame kit with frame off to allow lifting cover, head, cylinder....
Check your sprockets before ordering a new chain. The larger link is probably a 630 (6/8" pitch, 3/8" width), while 530 is 5/8" pitch.
Do a compression test before taking the motor apart. Also a proper leak-down test is done with the motor assembled.
Replace the guides. Bent valves will have damaged the guides, and the F motors were herded on guides than the Ks. Have the head surface skimmed flat and hone the bores.
I would try to find a different head. My $0.02 only.On Red I fought the whole battle with great results but it was expensive and took a while:- new guides, valves, retainers from CycleX- Neway cutters for three angle seat cut- final valve seat lapping
At a minimum rehone your cylinders. They should not be smooth but have a uniform cross-hatch. You can probably avoid an overbore.
