Author Topic: CB750 AHRMA Superbike Heavyweight Racer  (Read 37410 times)
Offline gschuld
Re: CB750 AHRMA Superbike Heavyweight Racer
« Reply #150 on: June 16, 2021, 06:53:02 PM »
Hey Brian.  I’m really hopeful this will be a fun racing season for both bikes.  Matt worked his tail off to get this bike ready.  There is a lot to be said for youthful energy, talent, a super understanding and supportive wife, and really impressive time management skills.
Fingers crossed both bikes will be relatively trouble free and offer Matt and Ashley some much deserved downtime between race weekends.
« Reply #151 on: June 16, 2021, 07:12:48 PM »
George, to best use your dyno time, start with the main jet. Check the AFR between 7000-9000 RPM with the throttle WFO; don't worry about the AFR at lower RPMs. Do a quick pull, and if the AFR is way off in either direction by 8000 or so, abort the run and adjust the jetting. Once you are happy with the WFO readings (AFR 12.8-13.2), you can move on to the needle, part throttle settings if you have the time. Just my 2 cents... ;)
Offline gschuld
« Reply #152 on: June 17, 2021, 03:00:39 AM »
Scottly,
Thanks for the tips.  I’m definitely welcoming any insights into dyno tuning.
George
« Reply #153 on: June 17, 2021, 10:31:59 AM »
+1 on Scottly
My WFO is spot on per the dyno. The mid range WAS 10:1. So now I'm using my butt dyno on the needles. Just dropped them one notch. Going for a butt dyno test next day or so. Maybe then another notch for comparison. If these were stock carbs I'd use the dyno to tune the needles. The CR31's and the RS34's are SOOOO easy to tune needles.
Offline simon#42
  • liverpool
« Reply #154 on: June 17, 2021, 11:31:21 AM »
the other reason i hate inertia dynos  is that you have a ton weight spinning round and if you have a problem with the engine you have to be quick with the clutch , if you have a problem with the gearbox you have to be quick to duck !
« Reply #155 on: June 17, 2021, 11:58:23 AM »
Needles easy to adjust on Mikuni TMR too. It will not affect synch.
Pilot jet another thing. I tested all in steps of 2.5 from 17.5 to 37.5 since last summer. My 2nd run like that and back down again but with different combinations.
One extra set of 4 float bowl gaskets is a must. 6 extra is good too since it is too easy to pinch them.  I have learnt how it should feel when assemble the bowls, all 4 hanging together with the acc pump hoses.
Red o-ring like material that expands by fuel. Another dry set is needed.  Old ones can be used a few days later if dried. I have heard that it is possible to cool the old fueled ones with ice to get them smaller again quicker.
All float bowls to be removed and assembled at the same time.
I have got the feeling for it after +20 times when carbs sits mounted.
Needle jet a small tube sitting on top of the main jet holder. Other carbs, everything as one  emulsifier tube. I guess RS 34 has same design as TMR.
CR31???
« Last Edit: June 17, 2021, 12:16:52 PM by PeWe »
Offline bear
  • Leeton in Australia
« Reply #156 on: June 17, 2021, 05:50:32 PM »
Dyno's aside. I would have thought a quick clutch hand would be a prerequisite for all you TZ pilots Simon.  ;)
« Reply #157 on: June 17, 2021, 08:21:53 PM »
Any updates on today's dyno testing????
Offline gschuld
« Reply #158 on: June 18, 2021, 02:53:42 AM »
Sorry guys.
It was a disappointment on our end, but an unforeseen issue prevented us from testing the bike on the dyno last night😕.  The bike is fine, and we are moving fwd.
Track testing/practice today, starting with the Sportsman bike.  We will have to do the best we can to dial it in on the track.  Any clear signs of trouble that can’t be dealt with trackside and the Superbike sits rather than risking the bike or rider.
« Last Edit: June 18, 2021, 05:28:19 AM by gschuld »
Offline Old Scrambler
« Reply #159 on: June 18, 2021, 06:52:43 AM »
Ahhhhh...........the best laid plans of mice and men..............So back to plan A..........Plug chops are likely to be fruitless because the race-gas/fuel will not leave deposits to read........Matt should know that if he has never heard detonation from a CB750, it sounds something like a dry roller chain spinning against the head and usually begins under acceleration at 4000+ rpms.........You will be able to read the exhaust in hopefully a nice mild gray.......If too rich, the motor will stumble and struggle under acceleration somewhere north of 7,000 rpms.
Of course you both know all of the above........it just may help to check all of the boxes ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline simon#42
  • liverpool
« Reply #160 on: June 18, 2021, 11:01:55 AM »
well they look like winners standing still , well done for turning out two bikes of this standard -
yes bear i still ride with two fingers on the clutch leaver at all times . logic tells me that modern road bikes dont seize up but my fingers dont believe me .
Offline hondaron
« Reply #161 on: June 18, 2021, 09:26:48 PM »
Both bikes look great
Good luck this weekend enjoy 😀
Offline gschuld
« Reply #162 on: June 19, 2021, 09:14:31 AM »
Not much of an update.  But as anyone could have anticipated, we were not able to beat the odds and have a trouble free first race weekend with an untested all new race bike.  Engine ran great FWIW.
I’ll let Matt explain later, but in short, nothing is hurt.  Minor issues to deal with over the next 4 weeks.  It’s no real disappointment as we expected issues would surface.
On a positive note, the Sportsman bike is running 100% trouble free.
FWIW, we want to thank those that have helped Matt with his racing.
Kenny and Mike especially.  Thanks guys…😂
George
« Reply #163 on: June 19, 2021, 03:19:51 PM »
Always a learning curve with any "new" bike fellas. The banner looks great!
« Reply #164 on: June 22, 2021, 03:31:33 PM »
I caught up with George Sunday evening, good work men. There will always be little issues with a new bike. Next time!
« Reply #165 on: June 22, 2021, 05:23:57 PM »
Glad you made it out and got it started down the road of sorting and tuning...
« Reply #166 on: June 26, 2021, 04:41:45 PM »
I'm waiting fellas.
Offline slikwilli420
  • Master of Disaster
« Reply #167 on: June 26, 2021, 06:58:53 PM »
The tale of two bikes. One, fettled and tuned for the last few seasons, fits like a great pair of gloves, gives (nearly) flawless performance, and is predictable. I know every piece and part of both bikes. The second, however, is new to me and the world, and while it shares so many things with my S750 bike, is its own unique creature in so many ways.
The fine tuning is yet to come but things have already come so far so quickly, and I couldn’t be more proud, despite the result. I left for Topeka over Memorial Day weekend, and the frame had just been painted, parts scattered around the shop and basement, a bike waiting to be born. I returned home from Topeka with issues to sort on the old warhorse, while also pushing to finish the new Superbike Heavyweight to debut at the Jersey round only a month later. And so it began, engine building, chassis assembly, the last little 5-minute bracket that takes half a day to get right, the whole deal. Many 16-18 hour days from early morning until well past 1am came to pass, every day inching closer to a very special machine, capable of competing with the best the air-cooled 4-cylinder era had to offer. It certainly took a toll on me and my family, but has proven to be a great adventure. Without a doubt it could not have been achieved without the support of my best friend, crew chief, and biggest fan, my wife Ashley.
The plan was to get it started and rings seated and head for a dyno session in northern New Jersey the Thursday of race weekend. Im thrilled to say that after some delay, the bike started and ran very nicely. I was able to make a few laps around the neighborhood at varying RPM to seat the rings and get a but a small feel for the bike. The upright riding position is something I am no longer used to, having only ridden my S750 bike over the last few years, with its low clip-ons and lay over the tank rider position, a mirror opposite of my new sit-up-and-beg superbike, with wide upright bars and cut down stock seat. Many nuances to adapt to are in my very near future. An extra 20+hp on tap, and only about 30lbs heavier, coupled with substantially better brakes (a single 12in rotor vs 2x 13in units), all in an effort to be competitive in a class of air-cooled monsters. Given all that, off to Jersey we went, old faithful and the new kid on the block.
The dyno session, as George mentioned, was quite the ordeal. This dyno had never taken advantage of its ability to start a bike, as it was nearly exclusively used for street bikes equipped with starters. After using my roller battery to hook up the never-been-used starting mechanism for the dyno, I thought we were in good shape. After some work the bike finally started and settled to a sweet idle. I get off the bike to look it over and see if there are any issues only to find fuel POURING out of the #2 carb overflow. The trusty wrap of a tool on the bowl as the bike is idling was not enough to right the issue with the float valve. At that point, it was quite a job to pull the carbs and assess the situation, with our dyno time already running out. The decision was made to try again at the track, and gently ease into running it, reading plugs as best we could and go from there.
We decided to start the bike again at the track without pulling the carbs on the off chance the valve had fixed itself on the last leg of the drive, and it had. A terrifying issue to be sure. Funny how things work, you load them up, then calamity ensues only to reverse itself again later. Old bikes man, that’s the game. Either way, it was time to get this thing out and finally get some actual track time. After a thorough warm up in the pits, its accelerated, turned and stopped as expected and it was my turn to practice. I head out on track, carefully easing into the feel of the bike, a bike I had never ridden in anger, on race tires I had never tried, on a track I had one session on so far, and a bike that had equal parts blood, sweat, and money poured into over the last year or so. As I gather enough speed after a few slow corners I gently throw it into the turn, and I feel it. The rear end starts wallowing, as if quickly finding and losing grip as I round the corner. Next corner, same result, and so on. I make it just under 2 laps and pull in to assess the issue. George notices as he stares at the rear ends of both bikes that the S750 wheel spins absolutely true rotation after rotation, nary a wobble to be detected. On the other hand, the Superbike wheel wobbles noticeably left and right and slightly up and down as well. While we likely had the wherewithal to swap the S750 wheel to the Superbike just to make sure that was the issue, we decided that it was time to throw in the towel and focus on what we could control, the S750 bike, which ran like a top all weekend. We also discovered the tiny oil leak from the copper base gasket had grown worse with my time on the track and more heat in the engine. It seems that its still trying to find its final home between case and cylinder and needs another round of torqueing to find that final home.
Back home after a successful weekend on the S750 bike (read about that in my other thread) I started to assess the rear wheel issue. I had just picked up another Astralite wheel complete with bearing hubs only a few weeks before, so I started mixing and matching hubs to wheels. The new wheel and its hubs spun true left/right and up/down as well as a true wire wheel so I had a baseline. I bolted my current hubs to the new wheel as they were already set up for the disc and sprocket, making the wheel swap a breeze, or so I thought. Just minutes before when the new wheel spun true on its hubs, it now spins like a drunken sailor on the hubs that came off the bike. Curious to say the least. I put the new hubs on my current wheel, and of course, the wobble all but disappears. It seems that I don’t have a wheel issue, I have a hub issue. I swap hubs and wheels back and forth and measure runout to see if it really is the hubs. The new hubs spun on both wheels substantially better then the old hubs did on either. Fortunately, despite being a quite different design, the spacing from hub face to sprocket mount was the same, and the disc carrier just so happened to be a perfect fit for the bolt pattern on my Ducati Monster rotor, what luck! With that, I have decided to use the new hubs (duh!) on the current 3.5” wheel, as the new 4.5” wheel would require a new tire, and I had just bought fresh race rubber for the 3.5. They both spun equally true, so that was a non-factor. I set about ordering fresh bearings and some of the long bolts required to bolt the hubs through the wheel, as well as a new custom sprocket, as the carriers are totally different in bolt circle and center hole diameter.
As for the leaky base gasket, the frame kit will allow me to pull the valve cover and with the help of the crow foot wrench I will be able to torque everything again, hopefully for the last time. There are a number of small things yet to finish on the bike, but without the crunch of getting ready for Jersey, I will have plenty of time to get things sorted. Remember, this year is for tuning and refining, and next year is for competing for points. Track time is a must this year so I can acquaint myself to my new machine and do as much tuning and fettling as possible before next season starts.
Gingerman is coming up at the end of July with a race the very next weekend at Blackhawk Farms so it should be a very eventful time of the season, hopefully with lots of good things to report about both bikes!
The glamour shots after final fitting of everything:
« Last Edit: June 26, 2021, 07:20:13 PM by slikwilli420 »
Offline hondaron
« Reply #168 on: June 26, 2021, 10:53:38 PM »
Thanks for the pics and updates 😀
Will see you at Barber for sure
Enjoy 😊
« Reply #169 on: June 27, 2021, 11:00:59 AM »
Just wonder why a copper base instead of mls? Did you need a special thickness the mls didn't come in?
Offline gschuld
« Reply #170 on: June 27, 2021, 01:00:32 PM »
Brent,
It was a race against the clock.  I had a number of new copper base gaskets of various the thicknesses. Matt ended up needing the .040” one.  Didn’t have the time to source an MLS BIG BORE gasket in .040”, assuming it was available.
An MLS gasket would have been preferred though.
George
« Reply #171 on: June 27, 2021, 01:40:36 PM »
Base gasket? Really 0.040?
Dynoman has RCS in thickness 0.010" and 0.020".
They have for various sleeves. Mikes billet block need 78 mm. I've used 78.11mm
http://dynoman.net/bikepages/sohc/gaskets-base.html
They have MLS headgasket for 72mm bore
0.03" and 0.04"
http://dynoman.net/bikepages/sohc/gaskets-head.html
I had to order some extra last winter.
Not available around here.
I guess CycleX has those sizes too.
I heard that base gasket can be reused with a very thin layer of "Wurth Super RTV Plus" and similar.
I tried to reuse 0.030"  MLS (72mm) head gasket, it had only around 500km and 2 dyno runs.
I did not get good compression test numbers direct after cam install + valve cover before carbs back on.
Had to order a new MLS head gasket plus some extra while order.
The protuded area around bores were flattened.
« Reply #172 on: June 27, 2021, 02:23:26 PM »
Brent,
George
Copy that.
Offline johno
« Reply #173 on: June 27, 2021, 06:12:51 PM »
George,
Ya getting there mate  ;)
just curious, did you anneal the capper gasket ? at .040 thick they are pretty damn hard and unforgiving. At that thickness I would anneal it then use sealant wisely as well.
ciao
« Reply #174 on: June 28, 2021, 06:35:54 AM »
I did not anneal the base gasket as I was under the impression they were dead soft copper already. George enlarged the holes for the larger sleeves and I carefully deburred all the edges and applied copper coat to both sides. Viton coated steel gaskets only come up to 0.020", and I am not sure if those can be doubled up but I have not had a single issue with them on my S750 bike. We needed to go thick on the base as quite a bit of material needed to be removed from the cylinder to account for a couple sleeves that had sunk after being run last.
I did find that after retorquing the head 24 hours after initial torque but without heat cycles that I was able to get another 10-15 degrees of rotation out of the head nuts. I was able to get to the two outside nuts after a few heat cycles and they turned an additional 10-15 degrees after that torque. With the frame kit I will be able to pull the valve cover and use a crow foot to get to all the nuts again, loosening and retorquing one at a time. I really hope this is enough to stop the oil from the base gasket. Of course the MLS head gasket is totally leak free.
