Author Topic: 1975 750F Wiring Harness Question  (Read 1322 times)
Offline RodSOHC750
  • Restoring Vintage Honda Motorcycles
« on: July 13, 2018, 01:00:26 AM »
I'm having trouble determining where the Right Handle Bar wires (Kill Switch, Start Button) connect to the wiring harness.  In the plastic junction box on front of the frame or inside the Headlight bucket?  They seem about 6 inches too short to make it to the plastic junction box.
1979 Honda CB750L Limited Edition
1975 Honda CB750F Super Sport
1972 Honda CL450
1970 Honda CT70
Offline Yoshimatic
  • The Stable
Re: 1975 750F Wiring Harness Question
« Reply #1 on: July 13, 2018, 01:10:38 AM »
I think they connect in the headlight bucket, the main wiring loom should finish in there and have wires of same colour waiting to be connected.
1969 GL175 twin
1970 CB750 K0
1971 CL350
1975 CB750F1
1977 CB750F2
1977 CB750A (original condition)
1977 CB750A (836 Cafe Racer)
1978 CB750F3
Offline RodSOHC750
« Reply #2 on: July 13, 2018, 10:41:49 AM »
The wiring harness from the right handle bar will reach the headlight bucket but not the junction box.  The wire mates will only reach the junction box and not the bucket.
1972 Honda CL450
1970 Honda CT70
« Reply #3 on: July 13, 2018, 11:45:29 AM »
Both harnesses from the bars go down the left side of the steering head, through the wire harness holder that's under the tank mount rubber, between the center and left downtube and into the top opening of the  junction box by the horn. Is this an original control or replacement? I have seen a replacement listed as fitting the CB750F0/1 that will NOT work as it is too short. I just yesterday sent Raf pics for this. If you match up the colors you will see as long as all the switches/colors are correct. Maybe check a schematic for color verification.
The clutch safety switch connects in the bucket.
Also, do you have the original tall -341 mid year K/F0/F1 bars?
I will gladly text pics if you PM your phone number or email them. My tank is off for a few days still.
ps your junction box is not properly mounted. The slot in it on the back goes OVER the tab/the tab fits inside the slot  ;) Your bike looks GREAT from what little I see! Nice paint and decal.
« Last Edit: July 13, 2018, 12:18:13 PM by Jerry Rxman Griffin aka MuthaF'er »
Offline RodSOHC750
« Reply #4 on: July 14, 2018, 10:44:32 AM »
I have 3 harnesses from the handle bars.  Do all 3 route down the left side of the steering head? I placed the tab inside the Junction Box slot which was no easy task as my box version had knurled nuts set inside the plastic box which started turning because of screw corrosion.  I sent my phone number via PM in case you wanted to send some pictures.  Thanks!
1972 Honda CL450
1970 Honda CT70
Offline Chief
« Reply #5 on: July 14, 2018, 02:38:48 PM »
Rod,  That blue paint is striking!  Pardon me but is it the original?
Thanks
Ralph
76 CB750F Super Sport
« Reply #6 on: July 14, 2018, 03:33:04 PM »
3 harnesses means you have non-original switches/controls. Keep in mind however that the wire for the clutch safety could be considered a third but it is not wired internally through the bars.
Offline eatpez
« Reply #7 on: July 16, 2018, 05:59:52 PM »
If you have an aftermarket switch on the right bar, then wires are too short. I ran into this on my F1 project. I ended up splicing the original wires onto the new switch.
