Author Topic: CB550 in a CB500 frame?  (Read 3049 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: January 12, 2007, 11:15:10 PM »
Just curious...does a CB500/4 engine fit in a CB500/4 frame? I know the question isn't very specfic, because I am not narrowing down years of manufacture etc. Just in general are there adaptibility problems?
1978 CB750K8; 1970 CB450
Offline GroovieGhoulie
  • I have to return some videotapes.
Re: CB550 in a CB500 frame?
« Reply #1 on: January 13, 2007, 01:03:11 AM »
It will drop right in, no problems.  That's what I've been told anyway.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: January 13, 2007, 03:06:55 AM »
I'm about to try this too.
Bryan Jones says that the rear right hand (as you sit on it) engine mounting plate is different (to fit the different clutch) so you'll need one from a 550. The frame is the same. You will also need a 550 clutch cable I believe.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #3 on: January 13, 2007, 05:50:54 AM »
Yes to the fit and RH rear bracket Nix to the clutch cable 500/550/750 all the same---yeh i know they are different part numbers but they will fit HONEST
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #4 on: January 13, 2007, 06:09:18 AM »
I have a 75' 550 in my 71' 500 frame. I know there are other parts that may be incomptable, like the brake lever(depending on the year)  clearence is super close to the case, and the kick starter was not swapable.
If you have a complete 550 motor you should have little to deal with...
I can't say enough about the improvement in the bike with the 550 in there, it is much peppier and the clutch is MUCH better. DO IT NOW!!!
« Last Edit: January 13, 2007, 06:14:04 AM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline gregwaits
    • waits music
« Reply #5 on: January 13, 2007, 06:19:26 AM »
Now I just have to find one!
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #6 on: January 13, 2007, 06:48:28 AM »
Be diligent, I found mine on ebay(2 months of looking) for $103.00 and it was so clean, no leaks, I dropped it right in my freshly powdercoated frame two years ago...no problems
oyu can see it in the gallery
SOHC Member#4000
78' 550
73' CL175
Offline gregwaits
    • waits music
« Reply #7 on: January 13, 2007, 07:04:50 AM »
Very clean! Nice job  :)
isred
« Reply #8 on: January 13, 2007, 07:56:29 AM »
Yes the 550 will fit, but so will the 650. you need the electrics from the 650 also, and the carbs. The power gain should offset the rewiring. Anyways just a thought, good luck on whatever direction you go, and keep us posted.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #9 on: January 13, 2007, 08:37:35 AM »
              Aw Man, You beat me to it. I was just going to say that the 650 would fit also. The clutch is an improvement with the 550. I'm not sure about what else. There's been some discussion on this before, and pretty detailed if I remember right.
                                                         Later on, Bill
Member # 1969
