Author Topic: Hesitation/bog  (Read 502 times)
Offline Madpiper
Hesitation/bog
« on: July 16, 2018, 04:34:35 PM »
Hi,
I’ve got a recently purchased 78 CB750K, that has a hesitation between 4-5k rpms in predominantly in 5th, Under 4 and over 5, things are good.
Since purchasing the bike I’ve cleaned and sealed the tank, installed an in-line fuel filter, changed plugs & air filter.  I’ve got more maintenance items to do, but was hoping the plugs and filter might have had a positive effect.
Am I dealing with a fuel, air, or ignition issue? Why only in a certain range/load?
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Hesitation/bog
« Reply #1 on: July 16, 2018, 05:22:58 PM »
i have that slight issue between 4 and 5k.  i think it's fairly common.  maybe someone else will disagree or have a fix for it.  if your tank is clean and you have the in-tank sleeve filter you could probably lose the inline filter.  those have been known to cause issues.
cb750 k6 - ugly
