Author Topic: hot wire a cb500  (Read 1964 times)
Offline loslobo64
hot wire a cb500
« on: July 18, 2018, 08:09:45 AM »
id like to know hot to hot wire a cb500 /4 just got it hasnt ran for three years  >:(
Offline DaveBarbier
Re: hot wire a cb500
« Reply #1 on: July 18, 2018, 12:36:20 PM »
Someone near you has a nice little 500 you’re looking to steal?
Offline ef9tuning
« Reply #2 on: July 18, 2018, 12:46:02 PM »
Why not troubleshoot the issue? Doesn't make much sense to hot wire it when you have the key...... ::)
1978 CB750K
« Reply #3 on: July 18, 2018, 01:06:47 PM »
Check circuit diagram. I had a switch on my CB750 hidden under the tank for several years since the stock ign switch gave up.
I think I wired them all 4 together to switch on.
Red 12V on one side of the switch- all the other on other side
CB750 close 12V Red from 15A fuse - Black which is main power.
Plus closing brown/white - Brown wire to rear light.   Brown white get 12V via a jumper to the black circuit.
This make it same thing to close Red 12V with all the other. CB500 switch can be same.
I used the wires from ign switch I had cut, soldered on a small switch.
There is also a number on Honda stock switches, maybe possible to order spare key. You must know type of key...
