Author Topic: Cb400F side Stand  (Read 1606 times)
Offline zeganso
Cb400F side Stand
« on: July 21, 2018, 08:11:42 AM »
Hi, all!
Just bought this CB400F and I'd say the lean angle with the side stand is a bit too much.
I removed the screw and tried to bend the tab a bit, back to about 4" from ground to side stand (while the bike was sitting on the center stand).
The thing is that as soon as I get her back on the side stand, she leans and bends all the way back as before.
What am I missing? Do I need to have this weld?
1972 BMW R75/5; 1977 Honda CB400F; 2001 Suzuki DRZ-400E
Offline robvangulik
  • Honda Fourever
Re: Cb400F side Stand
« Reply #1 on: July 21, 2018, 11:17:31 AM »
Would it be possible that the rear shocks are longer than standard?
Offline zeganso
« Reply #2 on: July 21, 2018, 12:58:17 PM »
Hi, Rob
I'd say they are. But ill measure them, just in case.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=7f670aoatcqjmf5ekmp1pkkd87&/topic,60973.0.html
« Reply #3 on: July 21, 2018, 01:26:21 PM »
i use 3,50 tires rear..and have same problem...use the senterstand..until i get veldet some ekstra on...
« Last Edit: July 21, 2018, 01:30:27 PM by strynboen »
i hate all this v-w.... vords
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: July 21, 2018, 05:24:06 PM »
check the frame where the side stand mounts, most likely rotted....Larry
Offline innovativems
    • Innovative MotoSports
« Reply #5 on: July 22, 2018, 06:03:40 AM »
Rust on the tube by the side stand is common.  Especially if you were able to bend the mount.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Bodi
« Reply #6 on: July 22, 2018, 12:49:48 PM »
Nothing should bend and then bend back, that's a bad sign that the stand mount area is rusted badly inside the tube. Likely to break off suddenly.
If the back wheel is an inch or so off the ground when on the centre stand, the side stand should leave the bike at a decent angle. If your rear wheel is on the ground on centre stand and you can push it off easily, the sidestand angle will be steeper. Maybe overly long shocks are fitted as the 400F ones are shorter than bigger Honda bikes but have the same end fittings and will mount OK?
Bigger than original tires will do the same thing.
If a bike is "cafe'd" and lowered the side stand leg is usually either useless or shortened to suit, maybe you have a modified leg?
« Last Edit: July 22, 2018, 01:34:12 PM by Bodi »
Offline zeganso
« Reply #7 on: July 23, 2018, 02:35:09 AM »
Thanks for the feedback, guys.
It doesn't seem rotted, as I had to put a bit of muscle to the wrench to bend it back.
Ill check both tires and rear suspension, just in case.
Offline Killer Canary
  • Typical Bran Muffin
« Reply #8 on: July 23, 2018, 06:14:35 AM »
My sidestand just about broke clean off this weekend.
Nothing for it but to prep and weld.
Kawi GPz900, H1
« Reply #9 on: July 23, 2018, 10:16:58 AM »
But you shouldn’t be able to move it at all.  Those are solidly mounted on that rail.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline zeganso
« Reply #10 on: July 24, 2018, 11:16:46 AM »
Welding it is!
