Author Topic: Emgo Muffler CB400F Bracket  (Read 1481 times)
Offline zeganso
« on: July 23, 2018, 08:50:36 AM »
Hi!
Had to get rid of the rusted out muffler that came with the bike.
For a quick fix, I bought a Emgo Megaton Reverse muffler.
The thing is, the mount isn't quite plug and play.
Can anyone recommend a bracket or share some images of a home made one?
1972 BMW R75/5; 1977 Honda CB400F; 2001 Suzuki DRZ-400E
Offline Bankerdanny
  • Endeavor to persevere
Re: Emgo Muffler CB400F Bracket
« Reply #1 on: July 23, 2018, 08:56:54 AM »
What you need to do is take a picture of the muffler attached to the header with the bracket on the muffler rotated up so we can see where is located relative to the frame.
The Kerker on my 550 uses a longer version of the strap shown your photo that reached from the mount on the muffler to the upper shock mount.
« Reply #2 on: July 23, 2018, 09:16:59 AM »
I like Kerkers but hate that long strap!   When I had one, I modified it to mount to the inside of the rear peg, worked fine.
Offline Bankerdanny
« Reply #3 on: July 23, 2018, 10:22:23 AM »
I agree, I was not a fan of the strap, but the fantastic sound kind of made up for it. The one that came on my 750F was clearly intended as a direct replacement of the OEM on the stock header because the bracket on the muffler is near the middle and attached at the factory point on the frame.
Offline zeganso
« Reply #4 on: July 24, 2018, 11:14:12 AM »
Thanks for the feedback guys.
I was avoiding welding anything as this is a bit of a temporary solution. The bike needs to be noise tested and the old exhaust was in shambles.
Offline Robbo
« Reply #5 on: July 24, 2018, 11:26:38 AM »
How about a Simpson’s Strong Tie or something similar, modified to fit, rounded off corners, and painted black ?
1973 CB350 Four, 1975 CB550K
Offline jakec
« Reply #6 on: July 24, 2018, 11:46:33 AM »
My friend just bought a 400F with a similar muffler. It's like reproduction in 2/3 the size of the original. Anyways the bracket that is shown on yours, the long straight one, his is similar although its longer and has a 90* twist in it to make it meet up with the mounts on the bike.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Bodi
« Reply #7 on: July 24, 2018, 04:15:29 PM »
Nothing says the muffler bracket has to be at its side. Put it down then bend the strap around and drill it to bolt to the bike bracket. You will need to make something for a centrestand stop as well?
