Author Topic: '71 CB500K jetting for pods and stock 4 into 1?  (Read 2927 times)
Offline Snoefy
« on: July 26, 2018, 04:49:33 AM »
I have a '72 CB500K, which came with a 4 into 1 exhaust and some paper/mesh pods (Emgo?)... And, yes, I'm looking to replace with K&N or UNI's.
Current jetting is 42 and 110 secondary.
Let me know your thoughts.
1971 Red CB500K "Rhonda"
Offline Snoefy
Re: '71 CB500K jetting for pods and stock 4 into 1?
« Reply #1 on: July 26, 2018, 05:10:10 AM »
What 4:1 exhaust?
Not sure, doesn't look to be a Mac. I haven't had any luck identifying the exhaust.
Here's a link to view the exhaust side of the motorcycle: https://drive.google.com/open?id=1oyL6c9BtnorGbltlMdRuyBC91Nr3v-Cn
Thank you for pointing out the 110 may be too high, I'll buy one size down.
Are 42's the correct mains? (or as close as it gets with pods).
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: July 26, 2018, 10:22:48 AM »
If it is a Kerker then the name will be engraved/stamped on the bracket that attaches it to the peg loop.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #3 on: August 09, 2018, 07:55:08 PM »
I would go 38 and 105.
As previously mentioned pods are not a huge difference at idle. Although you will notice differences starting the bike and warming up. 110 is a bit large for mains.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #4 on: August 09, 2018, 08:07:37 PM »
That is a MAC exhaust system
Offline Snoefy
« Reply #5 on: August 15, 2018, 04:43:23 AM »
Went with #40 and #105 and stock setting mixture screws.. but now I'm getting a really big exhaust blow back and popping noise when trying to start (I haven't been able to start her up yet). The blow back startled me quite a bit and now I'm a bit confused on why it's happening. Rather now keep trying and risk breaking something.
Does it mean the mixture is too lean?
Offline Snoefy
« Reply #6 on: August 15, 2018, 05:13:32 AM »
Sounds like you might have reversed the coil wires/plug wires
Hmm, I think you may be right. Without looking at my motorcycle I think I did 1/3 and 2/4 - Hopefully no permanent damage! And hopefully you're right and this solves everything  :P
Offline Snoefy
« Reply #7 on: August 16, 2018, 04:12:43 AM »
Thanks again for that suggestion, my green-self didn't check them after taking them off to check the valves.
Now, I'm back to square one as the idle dies without throttle.
« Reply #8 on: August 16, 2018, 08:14:44 AM »
Are all the head pipes getting equally hot?
Offline Snoefy
« Reply #9 on: August 16, 2018, 08:43:05 AM »
Not sure, haven't checked the pipes since rejetting down from #42 to #40.
Is it to make sure all 4 carbs are functioning properly?
« Reply #10 on: August 16, 2018, 08:54:09 AM »
Checking head pipe temp (relational) tells you which cylinders are firing and how even they are among them.  If  unevenness is caused by carbs, the throttle position determines which jet is dominant for mixture control. This can also be a slide position issue related to carb balance.
Head pipe temps are another informational tool to help diagnose the proplem cause.  If you had enough information, you'd know just what to fix, right?
Have you bench synced or vacuum balanced the carbs?
Have you accomplished the entire tune up procedure prior to carb meddling?
Have you looked at spark plug deposits to determine what's happening in the combustion chambers?
Offline Scott S
« Reply #11 on: August 16, 2018, 10:12:17 AM »
 How are you using the choke lever?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Snoefy
« Reply #12 on: August 16, 2018, 11:56:43 AM »
The further I open the choke the faster she dies off. I was unable to move the needle height as the screws were stripped, I was able to open a single one that had the needle placed on the 4th ring (highest/top) setting.
I bench synced prior to this last mount.
I can't remove the spark plugs as I don't have the tool for it, unfortunately.
Offline Scott S
« Reply #13 on: August 16, 2018, 05:45:21 PM »
 By open, do you mean move the lever horizontally or push down on it?
'71 CB500 K0
'81 Yamaha XS650
Offline Snoefy
« Reply #14 on: August 17, 2018, 07:24:42 AM »
Drain holes are impossible to unscrew - I'm stripping the screw trying to remove it, which may make it impossible to place back in..
Choke - by open I mean pulling it up horizontal to apply the choke, it's closed (not being used) when it is vertical on mine.
« Reply #15 on: August 17, 2018, 09:55:50 AM »
Look closely on the markings on the lever.
Lever up, choke on/ closed.  Lever down choke off/ open.
The throat butterflies are mounted at a 90 degree angle from lever angle.
For the drain screws, you'll need to fit the proper size driver to get good screw head engagement.  That's why they make different screw driver sizes.
