Author Topic: Muffler packing  (Read 1671 times)
Offline Bankerdanny
  • Endeavor to persevere
Muffler packing
« on: July 26, 2018, 01:13:22 PM »
I want to install the replacement Kerker muffler I picked up at Mid-Ohio. I repaired the damaged baffle but I am not sure what to do (if anything) for packing.
Do I need it? Is the baffle and end cone alone sufficient? Pick up a bunch of stainless steel scouring pads?
« Last Edit: July 26, 2018, 01:19:39 PM by Bankerdanny »
Re: Muufler packing
« Reply #1 on: July 26, 2018, 01:17:32 PM »
fibre glass insulation wool.
Re: Muffler packing
« Reply #2 on: July 26, 2018, 02:29:00 PM »
Depends on how your ears and brain perceive the alleged "noise"  ;)
https://www.ebay.com/i/361469466936?chn=ps
Even the Kerker competition muffler is not bad. I was pleasantly surprised.
Offline Handlebar
Re: Muffler packing
« Reply #3 on: July 26, 2018, 02:31:30 PM »
I repacked a Kerker for my 78f 2 years ago. Source up fiberglass muffler packing,wrap semi-tight around the baffle,then cut 4 strands of tie wire wrap the glass with the wire and secure the fiberglass. I put as mush glass as the canister would allow. Nice deep tone.
Offline kerryb
  • Not a very
Re: Muffler packing
« Reply #4 on: July 26, 2018, 02:46:14 PM »
I repacked an old kerker for my '78k with a fiberglass packing kit from the local cycle shop, $7.50 for the kit  I think.  Before packing it had a bit of a howl.  After packing (wrap and tie fiberglass) it had a very pleasing sound.  Insulation glass should work the same, just don't pack it real tight or hard.  Just my opinion from limited experience.
Offline przjohn
Re: Muffler packing
« Reply #5 on: July 26, 2018, 02:53:25 PM »
Any half decent dirt bike shop or Cycle Gear will have packing material. Do not try and use regular Pink Panther stuff, it will not last. The right stuff is cheap.
Re: Muffler packing
« Reply #6 on: July 27, 2018, 03:04:43 AM »
ya gotta pack it tight,any glass wool is fine,unless ya need special hipster café racer only #$%*?i can sell ya some.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Muffler packing
« Reply #7 on: July 27, 2018, 07:02:06 AM »
As long as it's sandcast!  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
