Author Topic: Alternative Rotor Bolt for CB750  (Read 941 times)
Offline Old Scrambler
« on: July 31, 2018, 05:14:42 pm »
We milled the rotor on my Salt Flats motor to use as a retainer to keep the starter gear intact. We have no shortened the retainer to within a few threads of the crank-end. Would like to locate a bolt with more threads toward the head as a replacement. Any suggestions?  I will check my CB & CL 77 parts bin.........maybe CB340-450?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Re: Alternative Rotor Bolt for CB750
« Reply #1 on: July 31, 2018, 05:39:50 pm »
Re-thread it maybe?
« Reply #2 on: July 31, 2018, 05:51:12 pm »
Are you going to have enough threads in the end of the rotor to use a puller if you ever need to remove it??
« Reply #3 on: August 01, 2018, 10:04:35 am »
Make a bolt on the lathe.
« Reply #4 on: August 01, 2018, 02:32:52 pm »
Made a grove in the collar for a steering-wheel puller if the conventional one fails............and yes, Dave is making a bolt this evening with that special fine thread..............thanks for the thoughts :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
