Author Topic: Float Bowl Cleaner - And The Winner Is:  (Read 17593 times)
Re: Float Bowl Cleaner - And The Winner Is:
« Reply #50 on: October 26, 2007, 01:12:40 PM »
Could someone that's used Simple Green confirm their long term satisfaction.
I'm gonna pull my motor, and paint it.  While the carbs were off I thought I would give em a soak in Simple Green to freshen up their appearance and get the gunk out.
Do I need to clearcoat them after with some lacquer?
I would not clear coat a carb. Heat will yellow it. The long term effect of Simple Green is it cleans them and they will get dirty on their own over time.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #51 on: October 27, 2007, 09:05:17 PM »
I'm an idiot... and as I sit away from home I'm kicking myself. I left a bunch of parts in a dilluted mix of SG at home because they were pretty dirty... and they've been in there for hours!
Guess we'll see how bad it is when I get home.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
754geyser
« Reply #52 on: December 29, 2007, 11:28:23 AM »
robbie or francis,i am member 2479.its sounds like you are into what i will be into soon,splitting carbs apart as leaking from the two tees is happenning.i don't know how this site works at all,maybe my member id will supply you with a-email so we can communicate.those 2 small hoses that horizontally join 1-2 and 3-4 together,can i get them if they won't come off.you mentioned about getting the o-rings for the two tees.available in ontario?my apologies to any members due to my computer ignorance.been reading this site since 2001,but never tried to communicate w/anyone as the need never arised.now it has.btw the bike is a 1973k3....thanks
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #53 on: December 29, 2007, 11:50:55 AM »
754: go to New Member Introductions and read the "Newbies Start Here" thread.
You've registered OK so that's the first step. Your email address comes up under the little envelope under your username.  Your user number is just a sequential registration number assigned by the forum software. It doesn't really mean anything.
Post your carb question in the technical SOHC4 section as you'll probably get more replies there.
Steve
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline francisew
  • Francis
  • Francis Esmonde-White
    • Esmonde-White.com
« Reply #54 on: June 30, 2008, 09:23:05 PM »
Hi 754geyser,
Sorry for taking so long to respond... basically the o-rings came in the carb rebuild kit. A good thing too, since the o-rings were more like little rubber c bits as soon as the carbs started to come apart. The carb rebuild kits are well worth the money!
Francis
Offline dpen
« Reply #55 on: July 01, 2008, 04:55:10 AM »
If anyone finds an Aust stockist could you post it please?
Offline DaytonGuy
« Reply #56 on: July 01, 2008, 03:21:53 PM »
Dare I ask this question......
What do you guys do with the old, nasty simple green that has been used to clean many parts?  Can you "simply" (pun intended) flush it or something.  What about old gas and the like?  Is there a disposal site in your county to "properly" dispose of these fluids?  Do you store them in containers of some kind?
Don't worry...I am in no way affiliated with the US EPA....lol
Offline eastoak
« Reply #57 on: July 01, 2008, 04:14:37 PM »
my county has 3 hazardous material disposal sites where they take parts cleaning rinsates and other haz-mat for free. this is your county site... http://www.mcswd.org/Community/SWD_Dropoffs/HHW2.htm
« Last Edit: July 01, 2008, 04:21:48 PM by eastoak »
« Reply #58 on: July 01, 2008, 05:19:45 PM »
Check this out http://www.hotfrog.com.au/Companies/Simple-Green-Australia
