I realized that the first gear does not jump out anymore. It would routinelly happen at stop signs and such. I guess it fixed itself, putting miles on Honda is the best cure.
Quote from: 70CB750 on October 05, 2022, 02:04:22 AMI realized that the first gear does not jump out anymore. It would routinelly happen at stop signs and such. I guess it fixed itself, putting miles on Honda is the best cure. Do the gears shift in a 'notchy'/tight way? is it required to completely back-off on the throttle similar to a BMW R75/6,etc. ?
Quote from: grcamna2 on October 05, 2022, 11:09:53 AMQuote from: 70CB750 on October 05, 2022, 02:04:22 AMI realized that the first gear does not jump out anymore. It would routinelly happen at stop signs and such. I guess it fixed itself, putting miles on Honda is the best cure. Do the gears shift in a 'notchy'/tight way? is it required to completely back-off on the throttle similar to a BMW R75/6,etc. ?I never experienced any problems with it. With clutch in to shift the transmission you just move the other shifter, too. Or you can keep transmission in gear, clutch in and switch high to low or vice versa. I think you need one .
Quote from: 70CB750 on October 05, 2022, 04:30:35 PMQuote from: grcamna2 on October 05, 2022, 11:09:53 AMQuote from: 70CB750 on October 05, 2022, 02:04:22 AMI realized that the first gear does not jump out anymore. It would routinelly happen at stop signs and such. I guess it fixed itself, putting miles on Honda is the best cure. Do the gears shift in a 'notchy'/tight way? is it required to completely back-off on the throttle similar to a BMW R75/6,etc. ?I never experienced any problems with it. With clutch in to shift the transmission you just move the other shifter, too. Or you can keep transmission in gear, clutch in and switch high to low or vice versa. I think you need one .Yes,I would like one. I may look to find a CB1000Custom with the same system.
Quote from: grcamna2 on October 05, 2022, 05:23:32 PMQuote from: 70CB750 on October 05, 2022, 04:30:35 PMQuote from: grcamna2 on October 05, 2022, 11:09:53 AMQuote from: 70CB750 on October 05, 2022, 02:04:22 AMI realized that the first gear does not jump out anymore. It would routinelly happen at stop signs and such. I guess it fixed itself, putting miles on Honda is the best cure. Do the gears shift in a 'notchy'/tight way? is it required to completely back-off on the throttle similar to a BMW R75/6,etc. ?I never experienced any problems with it. With clutch in to shift the transmission you just move the other shifter, too. Or you can keep transmission in gear, clutch in and switch high to low or vice versa. I think you need one .Yes,I would like one. I may look to find a CB1000Custom with the same system.Friend of mine has CB1000C and he does not ride anymore, but you are on the left coast, aren't you.
Prokop,what type of hardbags fit those side racks ?
Quote from: grcamna2 on November 01, 2022, 11:30:13 AMProkop,what type of hardbags fit those side racks ?Scroll up, there are pictures. https://www.harborfreight.com/4800-weatherproof-protective-case-x-large-black-64250.html
Quote from: 70CB750 on November 01, 2022, 12:45:38 PMQuote from: grcamna2 on November 01, 2022, 11:30:13 AMProkop,what type of hardbags fit those side racks ?Scroll up, there are pictures. https://www.harborfreight.com/4800-weatherproof-protective-case-x-large-black-64250.htmlYes,I remember you spoke about those cases and they seem like a great case even with some of the foam left in there to protect your valuables from vibrations.I just wonder about those side bag racks;they look like they originally were designed for a different type of bag,some large bag to fit into those open racks ?
Quote from: 70CB750 on November 01, 2022, 12:45:38 PMQuote from: grcamna2 on November 01, 2022, 11:30:13 AMProkop,what type of hardbags fit those side racks ?Scroll up, there are pictures. https://www.harborfreight.com/4800-weatherproof-protective-case-x-large-black-64250.htmlI lost all my pistols in a tragic boating accident. Oh, so thats where you stash your pistols when your riding?! Ha
Quote from: Stev-o on November 03, 2022, 03:22:17 PMQuote from: 70CB750 on November 01, 2022, 12:45:38 PMQuote from: grcamna2 on November 01, 2022, 11:30:13 AMProkop,what type of hardbags fit those side racks ?Scroll up, there are pictures. https://www.harborfreight.com/4800-weatherproof-protective-case-x-large-black-64250.htmlI lost all my pistols in a tragic boating accident.
They look good too.
Looks like it's always 'ready for the road' Prokop How's your sidecar rig's brakes working now after installing the disc brake on 'the chair' ?
Just took few pictures. Done with upgrades.
Quote from: 70CB750 on December 08, 2022, 01:00:17 PMJust took few pictures. Done with upgrades. Looks good. Just in time for winter...
