Author Topic: Recovering a seat  (Read 1068 times)
Sapphireminer
Recovering a seat
« on: August 07, 2018, 04:31:25 AM »
Hi all I am going to recover my old K7 750 seat but I notice a lot of the teeth that fix the cover to the pan are missing or are in bad shape is there replacement teeth? or some clip system I can fit to the pan Thanks for yor time .
Dave
Offline jlh3rd
Re: Recovering a seat
« Reply #1 on: August 07, 2018, 05:14:55 AM »
check out www.pandkclassicbikes.co.uk
and google phil turner.......you tube..
he sells repair strips, or used to....2008 is the date of his video..
« Reply #2 on: August 07, 2018, 05:38:30 AM »
 I have seen where people use contact cement and a bunch of clothes pins/clamps but I have never tried it. Upholstery 'tack strip' may be an option riveted on the pan.
« Last Edit: August 07, 2018, 05:44:52 AM by ekpent »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: August 07, 2018, 06:24:39 AM »
https://www.pandkclassicbikes.co.uk/A-GUIDE-TO-SEAT-RE-COVERING.html
This method works well for me:
New gator teeth upholstery strips riveted to the seat pan to hold the new seat cover:
New skin stretched into place:
All that work just for this:
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline beemerbum
« Reply #4 on: August 07, 2018, 08:18:52 AM »
Isn't that a K8 seat?
« Reply #5 on: August 07, 2018, 08:28:37 AM »
Yep. K7 would be similar without quite as much of a step between driver and passenger section IIRC. Procedure would be the same.  8)
Left the strap off for now, but you can see the indent in the foam where it used to be.
TAMTF...
Wilbur
Projects:
Offline johans
    • corporate leather
« Reply #6 on: August 07, 2018, 10:01:20 AM »
Damn , i wish i saw your post earlier . I own my own leather upholstery shop since 88 '  ( corporateleather.net ) and i could of saved you a ton of trouble . There are aviation adhesives   ( 3M 1357 ) that could of saved you wrestling with the mounting and fastening of the metal tacking strips ( furniture upholstery fastening system ) . W/ the adhesive you have more control of where the edge of the vinyl will finally end up ( i'm sure you know what i mean after upholstering the seat ) having said that ,the final product looks great !
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
Sapphireminer
« Reply #7 on: August 07, 2018, 01:29:14 PM »
Thank you for your replies this is just the info I was after I think you did great job on your seat madmtnmotors hope mine comes up as good.hope you all have a great day.
Dave
« Reply #8 on: August 07, 2018, 06:07:30 PM »
Thanks, I am happy with the results as well. I work for a sheet metal shop and am a sheet metal mechanic by trade so attaching the metal strips was pretty straightforward. I started pulling the cover over a couple on the sides and then pulled a couple over the points at the front and rear and then pulled the ones in between. Managed to get it to my liking on the first try! While I had the seat apart I pulled the foam, welded up a couple cracks at the edges, and glued the foam back to the pan. Saran wrap on the foam before putting the cover on helped prevent the cover from hanging on the foam and should also help keep the foam dry should I get caught out in the rain.  8)
TAMTF...
Wilbur
Projects:
