Author Topic: Does this 750 clutch look right?  (Read 3549 times)
Re: Does this 750 clutch look right?
« Reply #25 on: August 13, 2018, 02:19:31 PM »
This has never functioned before and is part of a rebuild that I took over (clutch was already 'done') and I have no history on any of these parts either.
That helps us determine what we are looking at. Looks like we need to determine which outer basket is being used and then determine the appropriate stack, pressure plate, springs, and inner hub that will match.
and clutch cover...............
« Reply #26 on: August 13, 2018, 06:02:13 PM »
I think all these issues have been solved?
« Reply #27 on: August 13, 2018, 06:06:51 PM »
or try a regular metal plate like PeWe suggested.
That's what I did; the way I figured it, one less friction disc made for a weaker clutch. ;)
Offline Johnny340
« Reply #28 on: August 14, 2018, 09:04:20 AM »
OK, so changing out that double steel plate for a regular one worked! I had the same thoughts on going with one less fiber.  I just finished welding that 'plate lifter' piece and it will be back together and working this time! :)
Thanks again everyone!!
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #29 on: August 14, 2018, 09:41:00 AM »
Did it weld ok, if not I have one here..
 There is a heavy duty billet one available  but at this point, just get it working first.
« Reply #30 on: August 14, 2018, 10:50:35 AM »
Good deal, back to stock. If it gets noisy you can always consider the "field fix".
Offline Johnny340
« Reply #31 on: August 15, 2018, 08:49:49 AM »
Thank you Frank.  It did weld ok so I think this little mystery is behind me now  :)
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
