« Reply #10 on: August 10, 2018, 08:32:18 AM »
I wonder if someone had access to an F model harness and swapped that in. The way the wires are set up in the F harness switching to a K setup with all the wires in the headlight bucket would be a pain.
Do you have the K2 style 4 warning lights between the bar clamps or an F/K7-K8 5 light dash between the gauges?
Replacement harnesses are surprisingly affordable. If you have the K2 warning light setup then I would find a replacement front harness for that, if you have the F later K style then I would look for a K7/8 harness that will work with your dash but hide the connections in the headlight bucket rather than the frame box.
Nevermind, I found your post in the project section, you picked up a '75 F0.
« Last Edit: August 10, 2018, 08:33:52 AM by Bankerdanny »
Logged
Current: '76 CB750F. Previous: '75 CB550F, 2007 Yamaha Vino 125 Scooter, '75 Harley FXE Superglide, '77 GL1000, '77 CB550k, '68 Suzuki K10 80, '68 Yamaha YR2, '69 BMW R69S, '71 Honda SL175, '02 Royal Enfield Bullet 500, '89 Yamaha FJ1200
