Author Topic: What do you use for vaccume when adjusting carb gauge tool  (Read 6253 times)
Offline Dos
  • Owner of a cb350f
Re: What do you use for vaccume when adjusting carb gauge tool
« Reply #50 on: August 19, 2018, 08:09:31 PM »
There seems to be a debate between whether it is okay to sync all four gauges to one cylinder.. can I get a confirmation that 1 cylinder to four gauges is OKAY? Or Wrong?
Offline Erny
« Reply #51 on: August 19, 2018, 10:29:15 PM »
I believe it does not really matters to which source you calibrate your gauges.
Important is they are calibrated (= showing equal value) on the same source.
So,in practice, I would choose 1 cylincer and attached one by one gauge onto it, recording value it shows. Shall be the same ideally.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
« Reply #52 on: August 20, 2018, 04:15:34 AM »
Cheap and simple works every time.
Haha, I suggested syringe in the reply #1.  Glad to see it actually works.
Offline rotortiller
« Reply #53 on: August 20, 2018, 05:16:37 AM »
I even moved the gauge position around on the connections to make sure they still maintained equality. Also altered damper settings during cal, basically extra effort against my better judgement after reading a bunch of posting BS. LOL ;)
Offline slikwilli420
  • Master of Disaster
« Reply #54 on: August 20, 2018, 06:59:10 AM »
10 days. Is this thing f*cking riding yet? Gotta be the longest discussion on syncing your sync gauges on earth.
Offline 1952paul0
« Reply #55 on: August 20, 2018, 07:08:43 AM »
yep they do make hard work of it.
Offline Dos
  • Owner of a cb350f
« Reply #56 on: August 20, 2018, 03:46:28 PM »
OK I did one gauge at a time and for the record It did not make any difference however the fourth gauge was off by one tick that is all
Offline Dos
  • Owner of a cb350f
« Reply #57 on: August 20, 2018, 05:39:37 PM »
Alright I have also synced my gauges.. at idle they are all at 8.. mid throttle they are also good however when I go FOT cylinder 3 or 4 will sometimes go out of wack
« Reply #58 on: August 20, 2018, 05:50:06 PM »
Please stop inventing procedure for tuning your carbs. Sync at idle then stop. There is no syncing carbs at other throttle positions. Please for the love of God go ride.
Offline Jetsurly
« Reply #59 on: August 25, 2018, 11:32:43 AM »
Sorry in advance for beating a dead horse here but could unsynced carbs be the reason my bike doesn’t idle and just dies at startup? If I rev while starting it’s fine but when I release the handle dies. Thoughts?
Offline Erny
« Reply #60 on: August 25, 2018, 02:45:03 PM »
I'm not expert, but I think sync only contribues to idle (its regular run). The fact that your bike does not idle should not be due just to sync.
Did you try to increase idle RPM by main idle screw?
Offline Jetsurly
« Reply #61 on: August 26, 2018, 02:35:18 PM »
Not yet. I’m on a work travel spree right now but as soon as I get home I’m gonna dedicate some time to this issue, as it’s my biggest one right now :(
