Author Topic: CB350F year  (Read 794 times)
Offline BazF
CB350F year
« on: August 11, 2018, 06:23:31 PM »
Gents,
I am having trouble sorting out the year of my CB350F
I believe it is 72/73, but which?
Frame CB350F 1024651, engine CB350FE 1028466
Are there build dates for these m/cycles?
Baz
BazF
Offline MoMo
  • Ride like you're invisible
Re: CB350F year
« Reply #1 on: August 11, 2018, 06:24:56 PM »
build date should be on the ID plate on the steering head...Larry
Offline BazF
Re: CB350F year
« Reply #2 on: August 11, 2018, 06:34:28 PM »
Thanks Larry, ID plate is not there, just frame No stamped.
Baz
BazF
Offline MoMo
Re: CB350F year
« Reply #3 on: August 11, 2018, 09:19:05 PM »
Baz
try this    https://www.motorera.com/honda/index.htm
Offline BazF
Re: CB350F year
« Reply #4 on: August 12, 2018, 07:20:56 PM »
Thanks, interesting site.
Looks like I have to live with 72 - 73. I was hoping to narrow it down.
BazF
Offline MoMo
Re: CB350F year
« Reply #5 on: August 12, 2018, 08:04:54 PM »
guess it is hard to do without the build date
Offline Robbo
Re: CB350F year
« Reply #6 on: August 13, 2018, 05:53:00 AM »
Baz, I have frame #CB350F-10314xx dated 10/72 if that helps narrow it down.  Interesting is that the motor is only 24 digits higher than the frame.
It’s registered as a ‘73 because it was sold and first plated that year.
1973 CB350 Four, 1975 CB550K
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
Re: CB350F year
« Reply #7 on: August 13, 2018, 06:11:21 AM »
In some cases the "build date" by itself will not tell you what year/model it is. For example, if the bike was built after September 1972, it would probably be a 1973 model. The missing VIN plate would solve the mystery, because Honda put "197x Model" on it.
Unfortunately, in most of the data available, Honda lumped the 1972 and 1973 models together. Only 1974 is identified separately.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
