Author Topic: 78 CB750k Tank Swap  (Read 1843 times)
Offline Mercer
78 CB750k Tank Swap
« on: August 12, 2018, 07:29:57 AM »
So I was cleaning out my tank when I realized it was beyond cleaning. The inside is rusted and it looks like someone tried to seal it at some point because there is a huge coating that is flaking as well. So, I need a new tank and I am fine with that since I wasn't a huge fan of the 78 tank anyway. My question is what other 750 tanks will fit my 78. I really like the 75-76 year tank and I can get a decent one for pretty cheap. Will this fit mine, I cant seem to find an answer elsewhere on the forum?
Thanks
Re: 78 CB750k Tank Swap
« Reply #1 on: August 12, 2018, 09:11:37 AM »
It will fit but there will be a gap between the seat and the tank.  Also the petcock may cause problems with the pd carbs
Offline Mercer
« Reply #2 on: August 14, 2018, 11:47:42 AM »
Excuse my ignorance here if this is a dumb question but what exactly do you mean by a "PD" carb? I'm assuming that the petcock on that year tank doesn't flow enough fuel for the carbs?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: August 14, 2018, 12:08:22 PM »
The carb's used on the 77-78 750k and the 77-78 550K are PD series carbs, I forget the actual models, but I think the 550 versions are PD44 and the 750 are PD46. The numbers are stamped into the manifold on the #4 carb side.
I think the issue Sean is referring too is potential interference between the outputs from the early style K tanks and the tops of the later style PD carbs.
Offline Godffery
  • Godffery's Garage
« Reply #4 on: August 14, 2018, 12:12:05 PM »
Your easiest swap would be the F model tank.   Mounts & petcock style & location are the same.
« Reply #5 on: August 14, 2018, 12:59:52 PM »
Goddfrey, is that tank for sale by any chance?
Offline Bankerdanny
« Reply #6 on: August 14, 2018, 02:54:22 PM »
Jeff, that might be the easiest swap to make, but it is the hardest tank to find next to a K0 wrinkle tank.
Offline Godffery
  • Godffery's Garage
Offline Bankerdanny
« Reply #8 on: August 15, 2018, 04:50:30 PM »
Here are a couple:
https://www.ebay.com/itm/Honda-Cb750f-Super-Sport-Gas-Tank-Cb750-Cafe-Racer/183376345763?hash=item2ab214faa3:g:dNoAAOSwX05bcPJj
https://www.ebay.com/itm/Honda-Cb750f-Super-Sport-Gas-Tank-Cb750-Cafe-Racer-Needs-Cleaned-And-Lined/183376346849?hash=item2ab214fee1:g:fZIAAOSwjwNbcPPm
 Also, I may be able to locate one threw my local Moto contacts.
I suppose I should have said not easy to find for reasonable money.
The first one looks useable, the second is rusted crap, and yet still the seller wants $200 for it.
Offline Godffery
  • Godffery's Garage
« Reply #9 on: August 15, 2018, 06:16:48 PM »
Here are a couple:
Yes, anything that is ready to use is gun'a cost 2 er 3 times that.  The way I figure it; We ether pay up front, or in the long run.  ;)
Offline Bankerdanny
« Reply #10 on: August 16, 2018, 08:37:14 AM »
Here are a couple:
Which is why the useable F2 tank I picked up at Mid-Ohio last month for $140 is the 2nd best deal I have made on SOHC4 stuff after the 750F Lester I just got for $100 shipped.
Offline Mercer
« Reply #11 on: August 16, 2018, 02:15:35 PM »
Here are a couple:
If you can track one down in your circle I'd be willing to purchase one, I was already eyeing the F tanks but they are always so expensive.
« Reply #12 on: August 16, 2018, 03:30:23 PM »
I'd recommend going with a CB750F tank 75-77.  IMO a better looking tank than the 77-78 CB750K tanks.
Offline Godffery
  • Godffery's Garage
« Reply #13 on: August 17, 2018, 09:46:34 AM »
Agreed. Also; if budget is an issue, using anything stock that's made to fit will be more cost efficient then building a custom application or modifying something to fit.
 I'll put the word out for you and LYK.
Offline Mercer
« Reply #14 on: August 18, 2018, 06:03:01 AM »
No worries, I actually ended up snagging a used 78 Super sport tank for around 200. Since all the mounts were the same I figured it was a good call and it wasnt a bad price. I do appreciate the advice, that was a good call. I can post some pics once I get it. My bike is still very early in the build process. I'm in the get it running stage lol
Offline Godffery
  • Godffery's Garage
« Reply #15 on: August 18, 2018, 10:46:59 AM »
Groovy!
I found a couple locally and the prices were in the $250 to $400 range so I'd say you'r do'n pretty good on that one if it's anywhere close to being ready to use.
 Post some pix of it on, when you get a chance.   (inquiring minds want to know)   ;)
Offline Mercer
« Reply #16 on: August 19, 2018, 07:33:40 AM »
Groovy!
Will do as soon as it gets here. I got to hear it run for the first time yesterday. Carbs were spewing fuel so tearing it apart again but it was a big win to hear it run. Hopefully I can just replace the needle seats and be good.
