Author Topic: D  (Read 2991 times)
Offline Sean CB550
D
« on: August 12, 2018, 02:31:46 PM »
My project: 1976 Honda CB550F complete engine overhaul.
Are the DYNOMAN products to be trusted? I purchased a set of valve guides and I need to replace all of the valves due to pitting on the stems.
Have you all had good luck with these valves? They sell a slightly oversized valve (28.5/24mm). Why would one need this? Wouldn’t it be best to simply purchase the standard (27.5/23mm) valves?
Are the “racing valve springs” and titanium retainers worth the money if my old springs measure just fine?
Are the Viton valve stem seals dependable?
There seems to be a great lack of OEM parts for the engine and these aftermarket parts seem to be in abundance. If the DYNOMAN products are trusted and proven it would solve a lot of problems.
« Last Edit: August 12, 2018, 03:14:07 PM by Sean CB550 »
Offline jaytee-nz
Re: D
« Reply #1 on: August 12, 2018, 05:43:38 PM »
You are in the wrong section - better to ask this question in the SOHC/4 Bikes section.
