Author Topic: CB650C runs like bad fouling plugs  (Read 2145 times)
Offline TurtleSnifferII
« on: August 12, 2018, 06:50:28 PM »
Been browsing this forum for more than a year now trying to figure out the mystery of my CB650C 1980. First, Ill start with I literally have no previous history from the owner on how it ran but it only has 14k miles on it. I was told he wanted to downsize since he literally had 10 + bikes in his garage and it appears to have been garaged the whole time. The bike runs rough and fouls plugs. When cruising around in 3rd it seems the bike surges and feels like each cylinder is fighting each other even though ive sync the carbs 3 or 4 times now. If I shift up at a lower rpm to 4th it goes away. The highest speed ive gone is 55mph and its usually around 5k rpm  which leaves the very tip of the white part clean and below it carbon fouled It spends most of its time riving it around 30 to 50mph. Ive literally been through 52 plugs now and counting ranging from D8EA to the current D8RES-L in it now.
About the bike
CB650C 1980 All stock
original airbox but no cover
4 into 4 original pipes
K&N air filter that came with it held by fender washers
Pilot screws at 2 1/8 but now at 1.5 turns out with after market
original paint :)
Now Ill try best to describe the symptoms but keep in mind this is my first bike and it was a project when I got it so I literally have no idea how a motorcycle should run or feel but I am however mechanically inclined. First thing I did when was get a new battery and change the plugs(cant remember what it looked like since that was 2 years ago). The bike started but choking it had no effect and I had to play with the throttle to start it. To it for a small ride but it was noisy and weak from the overly loose chain and squeaking at the wheels so I brought it back. Changed the oil and filter (which I destroyed with a pipe wrench)with lucas 10w-40 as the previous oil looked blackish and filter was black.
Then I removed the tank and flushed it with metal rescue which worked great in getting all the rust out and immediately filled with fresh 91 gas with 10% ethanol as California allows no fresh raw gas. After that I tackled the oil leaks by replacing the seals on the shifter shaft,cam cover, and the pucks inside the engine that were making a mess on the floor. Removed the carbies which are PD50 put all new float bowl seals, aircutoff valves, and rubber needles and adjusted the float heights to 12.5mm. Here I discovered someone elses work where the choke lever was broken so there was nowhere to mount the choke cable and jerry rigged a paper clip to operate both sides of the choke. I dissambled all carbs and soaked them and sprayed carb cleaner with compressed air several times since I've had the bike. All passages including idle air emulsifiers are clear as I have ripped them off to confirm. The pilot jets are the original Keihin 35 not drilled out and I replaced the stock 90 main jet to a 95 and put the carbs back along with a fuel filter that has good flow. I also eventuall changed the air vent tubes since they were hard and dried thinking with was effecting performance but not much change.
Next I tightened up the cam chain which was noisy unless it was the carbies.  After that I opened up the top and adjusted the valve clearance to .003 intake and .005 exhaust which was the HondaMan specs I think but am not to sure anymore where I got the .003 from. Compression test with a crappy HF tester gave me from left to right 115,110,110,115 but I know they read low and the hose it like 3+ feet long. Adding 3 drops of oil from a syringe did nothing to raise compression which is a good thing? At this point a year into the bike Ive been running it reguarly with 10w40 and with all new igntion components like new EMGO 2.5 ohm coils, new silicone copper leads, and new NGK 5K boots with helped to increase the spark strength  along with the now properly adjusted air gap at the pulse generator. The original coils were cracked and the bike would run like crap when it got hot.
 I also switched to the DR8ES-L spark plugs to for 10k resistance to stretch the spark and I must say it feels alot better instead of like an angry lawn mower. Also did an oil change recently to lucas 20w-50 synthetic since the oil smelled like gas the second time. Floats are not sticking open as I have tested so it must be with the engine running getting into the oil from not properly burning as plugs are rich and dry soot. All these adjustments helped make it a little leaner but still fouling plugs. Recently every plug I put into the #1 cylinder came out lean with some goldish color around the base ring but its fouling and the number #4 is now the leaner cylinder so whats going on? Maybe the valve clearance idk anymore. I discovered as well the the rubber collar from the airbox to the carbs had slipped out which was letting or the air out but now I fixed it so the choke works and revs the bike to around 3k and can be taken off really quick. A month ago dropped my bike like an idiot and poked a hole in the #1 rusted exhaust at the megaphone joint >:( but at least it sounds cool haha.(this was after the lean condition on the cylinder). At this point I even cleaned all electrical contacts and made sure everythings nice and clean, rotor and stator check out ok, battery is still good as Im on my second one now. What should I do? Ill post pics if needed, what ever you ask for.  Those 2 spark plug pics are in different lighting and the latest I had on was for 40 miles at different loads with the pilot screws at 1.5 turns. The ignitors also melted and I refilled them with epoxy if that helps. Pardon my rushed grammer.
Offline jgger
Re: CB650C runs like bad fouling plugs
« Reply #1 on: August 12, 2018, 08:33:24 PM »
I'll take a shot at it, but there are a lot smarter guys on here than me.
First, welcome aboard.
Now you know these motors run a "waste"  spark, they spark on the compression and exhaust stroke. That being said the plug 2nd from the right in your pics doesn't look to be firing too good. Since it shares a coil with one that doesn't look too bad, I would suspect either the high tension lead or the cap. Try cutting the wire back at the cap end about a quarter of an inch and reinstall it.
The other thing I would suggest is to do a clear tube test on the float levels, that same cylinder may be either leaking or too high. For the oil to have a fuel smell it is more likely a float level issue rather than a misfire.
Any way hope that helps and good luck
Jim
« Reply #2 on: August 12, 2018, 09:48:19 PM »
I completely forgot to mention the cleartube test thanks for bringing that up.  Ive tinkered with the float heights and set them higher than the 12.5mm setting to around 13mm to get the clear tubes to read 3mm from the gasket surface. All four carbs are just about equal with the #1 carb being a quarter of mm lower than the rest. The leads and caps are new but ill trim em just in case to see. When I ground the plug against the engine I get a good obese spark. Quick question regarding the carb sync for the PD50 so I sync each carb to #2 at the same time or all three to #@ at the same time cause I did it one at at time?
« Reply #3 on: August 13, 2018, 01:52:06 PM »
Anybody out there? Guess everyone's going after the easy topics...cowards.
Offline nswiston
« Reply #4 on: August 13, 2018, 03:18:20 PM »
I have the exact same bike. I had the same problems you originally had with the rough running at different range rpms. I cleaned carbs and had them synced professionally. What I’ve found is it’s more ignition related. Have you tested charging voltage? New battery? Often when you get weak ignition, it does weird stuff to the plugs also. Just a thought.
« Reply #5 on: August 13, 2018, 03:40:39 PM »
Thanks for the replies. I synced the crabs after I did the valve clearance but I had NGK D8EAs instead of the DR8ES-L I have now. Im going to sync the carbs again and see what happens since I changed the idle screws from 2 1/8. What should I do for the ignition test specifically? The stator and rotor check out okay according to book specs but not sure about those ignitors I refilled on how to test them. Battery after charge rests at 12.8 after a few hours and then after a couple of weeks stays at 12.6. I took it to the store and it tested good.
« Reply #6 on: August 13, 2018, 10:14:59 PM »
I checked the CDI thing in the book and it recommends to check with a known good set of ignitors if that's you mean. How do I test those? The pulser also seems within spec in the pics below measuring ohms at both blue cables and both yellows for 1+4 and 2+3. The coil test says to check by grounding the plugs against the engine and doesn't give anything to measure. I get a blue spark with fresh new D8RES-L plugs with the gap at 0.7mm. I noticed after cranking on and off for three minutes with a fully charged battery only one plug seems to get get all the power staying blue and the rest will fade intermittently between a blue and orange spark.  Whats that about?
« Reply #7 on: August 15, 2018, 05:49:05 PM »
Does anyone here know how to do that GM HEI ignition conversion? I dont want to pay over 200 bucks for those black ignitors when they are not that reliable. I would like the GM ignition since it sounds like a fantastic option and the parts are very affordable but not sure about wiring or what type of coils I would use for it.
Thoughts anyone?
Offline jgger
« Reply #8 on: August 15, 2018, 07:21:10 PM »
The 650 forum has a write up on it, hop over there and do a search. I will see if I can find a link at least to the forum.
http://hondacb650.com/viewtopic.php?f=4&t=3142
There ya go try that and let us know how it turns out, I have toyed with that idea if/when I finally get mine running.
Good luck
« Last Edit: August 15, 2018, 07:27:39 PM by jgger »
« Reply #9 on: August 16, 2018, 11:43:41 AM »
Ive been reading through it but I cant seem to find the difference between the 7pin and 4 pin they use. The 7 pin looks like it has automatic dwell, do I need that on the 650? The 4 pin looks like an easier and cleaner installation. I wonder if it also work with my current 2.5ohm coils or burn them out.
Offline jgger
« Reply #10 on: August 16, 2018, 06:43:03 PM »
It's been awhile since I read through that but right at the beginning of the article I linked he said that he used a 7 pin on his. Said you don't use all the wires and I thought it had a diagram of how to wire it up.
There might be a 2nd article on that same site too, did you sniff around?
Spent a little time reading and saw this in that article------
Coil number C849 "Ignition coil for a 01 Chevrolet cavalier with 2.2 4 cylinder please."
Ignition module DR100 "Ignition control module for a 1984 Chevrolet C10 with the 5.7 please."
Does that help?
« Last Edit: August 16, 2018, 07:38:21 PM by jgger »
« Reply #11 on: August 16, 2018, 11:05:00 PM »
Thanks for finding that, I noticed almost all the links are broken on that page. After 15 pages of staring at a screen I started spacing out and skipped it probably.  I'm going to buy the parts and get some backup for wiring it all together, if I don't kill myself that is.  ;D.  I'll post a video if I can get it to work once I get the parts just in case anyone else is interested. I decided on the 4 pin.
« Reply #12 on: August 19, 2018, 02:59:53 PM »
Just thought I'd add that the battery was tested bad. Hooked it up to a car battery and got good blueish white spark. I wonder if using the HEI modules is necessary anymore or if it will make it any better.
Offline jgger
« Reply #13 on: August 19, 2018, 03:26:32 PM »
You know the battery is bad, replace that then go over your charging system.  Might be all it needs........but I'm cheap,why go through all the extra work? Besides if the charging system is bad it will screw with the HEI. But that's just me!
