Author Topic: Tappet Cover broken  (Read 842 times)
Offline Can550
Tappet Cover broken
« on: August 12, 2018, 08:34:47 PM »
Quick question on a broken tappet cover (CB550)
I have two tappet covers that have crack and a little chip holes in them, would it make any difference in running of engine? by sucking extra air?
Thanks,
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Tappet Cover broken
« Reply #1 on: August 12, 2018, 08:43:01 PM »
Probably wont make a difference in running butbthats a easy place to get moisture into your engine.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: August 12, 2018, 09:13:03 PM »
They just seal the holes, nothing structural. Still, you can get brand new ones from David Silver Spares and 4into1 and a number of other places, and there are plenty of used ones on EBay. I would just pick up a couple replacements for the long-term.
Online RAFster122s
« Reply #3 on: August 13, 2018, 01:20:47 AM »
If they seize a broken one can be a real pita to remove.  But that would be true if it were not broken...
Offline Little_Phil
« Reply #4 on: August 13, 2018, 01:26:46 AM »
Same caps as lots of small Hondas, 50cc etc. Use 6 sided drive only on them as they always seem 16.8mm head!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #5 on: August 13, 2018, 04:23:44 AM »
16.8... that explains my troube getting the ones a PO over tightened off my 500.....
Offline Can550
« Reply #6 on: August 15, 2018, 10:03:28 PM »
Thanks everyone
I had ordered new caps but just wanted to ensure that leaky cover isn’t like leaky carb boot.
« Reply #7 on: August 16, 2018, 12:29:54 AM »
get a cheap six side socket and grind the opening so the lead in ramps are gone like the one on the left here.
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: August 16, 2018, 05:27:34 AM »
When installing the new ones keep in mind that they're just oil seals and should only be put on snug, not super tight.  That huge "nut" on top tends to make a lot of people assume they need to be really cranked down.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #9 on: August 16, 2018, 06:42:42 AM »
Smaht!
Then just tighten it by hand, or at most a finger ratchet.
--Evan
1975 CB750K "Rhonda"
« Reply #10 on: August 16, 2018, 08:38:18 AM »
+1
I don't know why so many people assume they need to torque these covers down.
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: August 16, 2018, 10:25:55 AM »
+1
A lot of it's probably due to people trying to stop a leaky tappet cover by tightening it instead of just replacing the old seal.
« Reply #12 on: August 16, 2018, 10:34:09 AM »
+1
True.  Also, since covers don't come with seals, many people re-use the old worn out ones.
