Author Topic: Aftermarket manifold boots  (Read 645 times)
Offline zabzob
« on: August 15, 2018, 06:59:35 PM »
I've got a 75 CB750 with rock-hard manifold boots. I'd like to eliminate them as a source of possible air leak, as well as eliminate the frustration of trying to get my carbs back on when it comes time to do so. Honda ones are looking like $120 to my door. Anybody used the far cheaper aftermarket ones? Any issues?
1975 CB750K5
Offline dusterdude
Re: Aftermarket manifold boots
« Reply #1 on: August 16, 2018, 03:32:55 AM »
Vintagecb750.com has nice boots but they're about 100 usd
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #2 on: August 16, 2018, 03:35:50 AM »
My bad 88.00
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: August 16, 2018, 06:43:22 AM »
I had those ones and they cracked after only two years. :(
--Evan
1975 CB750K "Rhonda"
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: August 16, 2018, 07:20:08 AM »
Pro tip: Go with OEM if you can.
Offline zabzob
« Reply #5 on: August 16, 2018, 06:50:18 PM »
You are right. I can either go OEM and have them for 20-30 years or replace the aftermarket ones in 5 or 10. I've already decided against the aftermarket cam chain tensioner based on horror stories I heard here.
1975 CB750K5
« Reply #6 on: August 16, 2018, 09:47:48 PM »
I tried cuzinimage cheap boots, deep cracks after a few months! Price vs life not good = very expensive.
You risk the engine when boots are cracking, leak air causing lean. My old Honda boots never cracked, only too hard.
