Author Topic: PD46A disassemble  (Read 416 times)
Offline WolfRider
PD46A disassemble
« on: August 15, 2018, 06:11:33 PM »
Time for some carb cleaning and also checking what kind of jets I have in there. Only problem is, how do I remove these two screws: https://imgur.com/a/wqb9rbs
Also if anyone is interested:
Main Jet: 100
Slow Jet: 42
Jet needle: E2350F & 2nd clip position.
77 Honda CB550K3, pod air filters
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: PD46A disassemble
« Reply #1 on: August 15, 2018, 06:14:39 PM »
i don't have those carbs but i imagine allen wrench.
cb750 k6 - ugly
Offline WolfRider
« Reply #2 on: August 15, 2018, 06:25:29 PM »
Yeah, the one on the right is probably an allen wrench but it's stuck like hell. The one on the left is completely round so don't think an allen wrench would work.
Offline brewsky
« Reply #3 on: August 16, 2018, 01:21:28 AM »
The one on the left is a roll pin.....just knock it out with a punch if you must
The one on the right is a 3mm allen head....soak it with penetrating oil, make sure the hole is completely clean, apply some heat, apply some valve grinding compound to the end of the allen head wrench before inserting, and give it a quick turn counterclockwise
https://www.acehardware.com/departments/tools/power-tool-accessories/grinding-wheels-and-compounds/82658?x429=true&cid=CAPLA:B:Shopping_-_Catch_All&k_clickid=a32b5848-cbf8-4015-b730-c48ca9028089&msclkid=f4e1bf2b6de8161265f2e45e594748e3&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%20-%20Catch%20All&utm_term=4581664954601403&utm_content=Catch%20All%20(New)
If that doesn't work, find some left hand drill bits and a new set screw
« Last Edit: August 16, 2018, 01:25:07 AM by brewsky »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline WolfRider
« Reply #4 on: August 16, 2018, 09:24:54 AM »
Thanks for the tip, Brewsky. Gonna buy the grinding compound and 3mm allen wrench.
Offline 2wheels
« Reply #5 on: August 16, 2018, 10:30:34 AM »
I was going to say you may need some heat for the one on the right.  It may have locktite on it.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
