I’m having some shifting problems.
Already found a topic that explains how to drill the clutch basket and other stuff. However my problem isn’t exactly the same and I don’t want to camouflage it with this method...
So, i fully restored my cb500 four. It have 10w30 oil with the right level.
Everything seams to work great now except the clutch.
All shifts are working but not always easy to shift!
Sometimes is just hard to shift and if I rev, it shifts easier.
Other times it jumps to neutral, even if I’m shifting from 3rd to 4th, however if I try again it’s shift on 4th, not 2nd. So it wasn’t really on neutral, but not sure where it was.
It’s not really that shift problem that I can’t shift when it is hot. Sometimes it enters at first try, sometimes I need to try 2 or 3 times with revs...
With low revs they are really hard to shift.
When it enters, there is a big change that the pedal stays in the upper position and after a few seconds it drops to normal position by itself...
Another thing that I’m not sure if it’s normal... when stopped i can’t shift all gears. I need to move the bike back and forward.
At last and not so common like the other issues, sometimes it’s hard to get neutral. It jumps from 1st to 2nd or from 2nd to 1st. But with the engine stopped it’s easy.
Sorry for the long post. As I said, I want to know if there is something else going on here. I don’t want to camouflage the issue and damage anything with the time.
Cheers!
