Author Topic: Has anyone double disc'ed a Lester?  (Read 1440 times)
Online Don R
« on: August 23, 2018, 08:00:52 PM »
 Title says it all. I already pinned the speedo drive to the wheel hub. Just wondering if anyone has actually done it. I doubled up my 76F, it worked and looked awesome.  This will be on my diecast hot rod bike. I remember swoop asking and whaleman having done it a few years ago.
 I do have a nice K0 rotor and caliper, I should save them for another bike.
« Last Edit: August 23, 2018, 08:08:13 PM by Don R »
Re: Has anyone double disc'ed a Lester?
« Reply #1 on: August 23, 2018, 08:55:46 PM »
Just compare the lester hub to a stocker, if they are functionally the same, which I assume they are, it's the same as putting dual discs on a stocker.
Online Don R
« Reply #2 on: August 23, 2018, 09:10:21 PM »
 I thought I'd ask before taking the Lester off the bike. Winter project pre-planning. Thanks.
« Reply #3 on: August 23, 2018, 10:51:20 PM »
Do a good write up for us Don  ;) Sounds like a good project for my hot rod.
Offline slikwilli420
  • Master of Disaster
« Reply #4 on: August 24, 2018, 05:00:48 AM »
I found that center of hub to rotor mounting face on each side was not the same on mine. I had a machine shop take material off that face to get them to match. Then the rotors didn't look weird from the front and I was able to use mirrored brackets for the calipers.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: August 24, 2018, 05:42:39 AM »
Isn't the Lester for the 500/550/750 the same as the one for the Goldwing, which is dual disk stock?
Offline rotortiller
« Reply #6 on: August 24, 2018, 06:07:29 AM »
Yes back in 1980. LOL
Offline Rookster
« Reply #7 on: August 24, 2018, 06:42:11 AM »
I did this write up a couple years ago.  The picture links were all broken so I tried to add them back in but a few are missing.
http://forums.sohc4.net/index.php/topic,91781.msg1025007.html#msg1025007
Scott
« Reply #8 on: August 24, 2018, 06:33:14 PM »
The stock wheel hub mounting faces are also offset; the left side face is .120" closer to the fork leg than the right side. The bearings are also not the same offset on both sides, which makes me wonder how guys are centering the rim when lacing and truing spokes; there is no reference point for the center of the hub?
Online Don R
« Reply #9 on: August 24, 2018, 07:58:37 PM »
 Good point scottly, I just duplicated the front rim/hub relationship of another rim so it's probably still offset. I trued the rear in a swingarm with the bushings in place.
 It's possible when the gl1000's came out they adjusted the Lesters to work.
« Reply #10 on: August 24, 2018, 08:16:35 PM »
My Morris wheel has the offset in the bearing carriers; the center of the wheel hub is symmetrical to the outer edge of the rim area. I spent a fair amount of time trying to measure this accurately, and found that there was an error of .040 in the Morris carriers. My advice is to check the spacing from the rim to the fork lowers; this should be the same on both sides. It's hard to measure with K forks, but the F2/3 forks have machined surfaces for the fender mounts that line up closely near the rim, which made for an easier job.
Offline Whaleman
« Reply #11 on: August 25, 2018, 05:38:41 AM »
I did a long time ago. Dan
Offline Whaleman
« Reply #12 on: August 25, 2018, 05:42:44 AM »
Another picture.
Offline Scott S
« Reply #13 on: August 25, 2018, 09:44:07 AM »
 Yes, sort of.... but it's been modified. Machined and spacers made to fit the R6 front end.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
