Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
That's an exact replica of Charlie's Place, which I use, and recommend. Avoid Pamco!Sent from my SM-G955U using Tapatalk
Quote from: 540nova on August 26, 2018, 06:43:06 AMThat's an exact replica of Charlie's Place, which I use, and recommend. Avoid Pamco!Sent from my SM-G955U using TapatalkThanks Nova. Do you use the original unit or their upgraded (orange pickup) unit?
I, on the other hand, have thousands of trouble free miles on Pamco's. Twins, fours, Honda, Yamaha.... never had an issue.
What " optimized duty cycle" are you refering to?The stock points are optimized at 190 degrees, and adjustable ( via gap).The Dyna s is about 270 degrees.The Pamco (IIRC) is 120 degrees.Dwell optimization refers to coil saturation time in crank angle degrees. But, you haven't mentioned what coils you are using or what the manufacturer of the coils chosen requires for their coils.Cheers,
Now don't let us mistake dwell which is measured in degrees for duty cycle which we (and Tytronic) measure in percentages. Actually - without further knowing the Tytronic - what I think is smart, is that they limited the duty cycle to 50% or 45, 90 or 180 degrees dwell angle (depending on what scale you use) and so enable their product to be used on most bikes. Believe me: for saturation of either 3Ω or the standard 4,7Ω coils 50% is plenty and will safeguard you from too much draw.
I have had mine for a bit on a CB750. Here is a link if you are interested. https://www.facebook.com/media/set/?set=a.1691476597537846&type=1&l=e9e62094bb
Been having intermittent ignition issues with my 550 for quite some time now.
