Author Topic: cb350F Headlight Switch Replacement  (Read 628 times)
Offline zcb350fb
« on: August 27, 2018, 01:41:33 PM »
Has anyone replaced the right hand hi-low beam, on/off switch? The lights went out on my bike. I opened up the switch housing and found that the plastic piece inside the switch that slides from off-low-high, had cracked in half beyond repair. I got the headlight to stay on in the low beam position so now anytime the bike is on the low beam stays on. this isn't a bad thing because at least the light is working but has anyone replaced this switch to get the off-low-high modes to work? If so did you find oem parts or will other model's right hand controls work?
1973 cb350f
