Could a head light on/off/high-low beam control switch breaking cause the main fuse to blow.
A few months back, main fuse blew while the bike was running when I switch the headlight from off to high-beam. I replaced the main fuse and the bike was fine for a month. then a month later, the head light switch broke. (the little black plastic piece that slides between off/on/low/high inside the switch cracked in half beyond repair.) I was able to get the headlight to stay on low beam and it worked. then the fuse blew a month later and I replaced the fuse again and now fine. so basically I am wondering if all of these fuse issues stemmed from the failure of the headlight off/on/high-low switch? Where should I begin to look?
I also checked and cleaned ground under the seat. are there any other grounds that I should check?
I never had fuse issues before. I have had the bike for a year and these issues never arose until now
