Author Topic: CB500 Four K1 1972, currently mid mono-shock, working on engine  (Read 10065 times)
Offline Register
Re: CB500 Four K1 1972, currently mid mono-shock, working on engine
« Reply #75 on: June 14, 2020, 06:04:07 AM »
Finally got all the wiring sorted - what a headache.
Mix of incandescent up front and LED at the back means the indicators don’t yet flash but everything else works ok.
I hadn’t figured on the happy brake light set up however.
Offline Register
« Reply #76 on: August 31, 2020, 03:43:40 AM »
Bit of an update -
Managed to extend the lead on the secondhand coil using a copper nail and some shrink wrap. Works perfectly.
Thanks someone for the tip on wiring in the electronic tach. Also works perfectly.
Finally got some primer on the tank (should have done better with filling the indents) and bump seat.
Need to figure out how to fix a pad of some sort. And clean the paint off the rear lights.
Found an adjustable ‘resistor’ on eBay that allows decent flash rate with incandescent and LED indicator mix.
Making very slow progress but almost there.
« Reply #77 on: August 31, 2020, 10:00:39 AM »
You may want to add some seat foam material toward the edges.  Right now you have more foam protruding into your nuts and ass, which won't be very comfortable except for very short rides.  On longer rides, it will apply pressure on those parts of your body.  If you ride aggressively, it will not provide any support as you hang off to your ass cheek, and you will tend to slide off the seat.
Just my$0.02.
Offline Register
« Reply #78 on: August 31, 2020, 10:39:42 AM »
Thanks for the heads up. That was just quick look.
I made a base just now and mocked up something a lot better.
Need to work on how to cover it.
« Last Edit: August 31, 2020, 10:44:33 AM by Register »
« Reply #79 on: September 01, 2020, 08:34:09 AM »
Definitely much better.
Offline Register
« Reply #80 on: November 15, 2020, 01:04:20 PM »
Creeping forwards.
My daughter sorted the saddle so I added a couple of tape stripes to the primer. Could work if I had the skills.
Next stop fix the leaking carb - wish I’d used allen head bolts.
And uncover the tail lights.
Offline Register
« Reply #81 on: May 02, 2021, 12:39:27 AM »
A couple of photos after final very DIY paint
Offline Register
« Reply #82 on: May 09, 2021, 01:21:39 PM »
I need some help diagnosing a top end oil leak please.
Looks to be coming from the internal area around the barrels.
Hopefully photos explain.
Thanks
Offline Shtonecb500
    • Youtube profile
« Reply #83 on: May 09, 2021, 08:39:22 PM »
nice progress, are you running 18" front and rear?
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Register
« Reply #84 on: May 09, 2021, 10:08:44 PM »
I'm running 19" front 18" rear. Ali rims ss spokes
