Author Topic: Homebuilt motorcycle table size  (Read 1122 times)
Offline Gurp
  • I'm no.......
  • Once was a...
« on: September 01, 2018, 10:53:39 AM »
Those of you with homebuilt motorcycle tables how wide amd how long did you make it?
I was wondering as i just build a short table 14in height for my ex brother in law.
I built it from scraps from my wood pile.
Going to be building one for myself soon so was wondering what everyone else ls set up is like.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline 72 yellow
Re: Homebuilt motorcycle table size
« Reply #1 on: September 01, 2018, 01:29:12 PM »
I made mine in two 25x48 sections 17 inches high.  Easy to store by stacking when not in use.  Also can use one for lawn mower etc. repairs.  I use a long bolt to hold the sections together.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2 on: September 01, 2018, 06:57:52 PM »
Yellow i like that set up. Do you just have a hole drilled that you run a bolt through or a latch?
Offline 72 yellow
« Reply #3 on: September 02, 2018, 11:35:46 AM »
Just a long bolt through a drilled hole.
Offline Alan F.
« Reply #4 on: September 05, 2018, 04:29:38 PM »
I built mine from this page:
http://dropbarscinder.blogspot.com/search?updated-min=2011-01-01T00:00:00-08:00&updated-max=2011-03-03T10:35:00-08:00&max-results=20&start=12&by-date=false&m=0
Two sheets of 3/4 plywood and only 4 cuts, lots of screws and glue but its amazingly solid.
24" high plus 4" for casters. I'd make it closer to 20" if I had it to do over.
