Author Topic: Bike dies and really badly fouled up plugs after only 150miles  (Read 1097 times)
Offline tommychains
« on: September 04, 2018, 08:53:30 AM »
Hi guys, I've had constant issues with my '78 CB750F running poorly and eventually 1 then 2 cylinders quitting altogether. It seems to run fine again when I change the plugs. I've attached a pic of the plugs taken out after only 150 miles. They're really fouled. Is this likely just due to overly rich mixture? I will be looking at taking apart the carbs and taking the jets down one or two levels. Can there be something else causing this though? I have air pods, electronic start, and 4-1 aftermarket exhaust on the bike.
Re: Bike dies and really badly fouled up plugs after only 150miles
« Reply #1 on: September 04, 2018, 09:14:55 AM »
Look like floats are floading. Verify float heights, floats not blocked, float valves can close.
« Reply #2 on: September 04, 2018, 10:35:54 AM »
when was the last full maintenance performed?  valve adjustment, timing/advance, carb clean/vacuum sync...etc?
what jets are you running for your pods?
clear tube test your fuel height....its easy on your PD carbs.
Offline tommychains
« Reply #3 on: September 06, 2018, 06:55:57 PM »
Thanks for all these tips folks!
-cylinders 1&3 die, so it's not likely related to ignition
-I haven't done any valve adjustment, timing/advance maintenance done, so I'll look into this
My first step will be a take another close look at the carbs and check floats.
Flybox1, can you elaborate what you mean by "clear tube test your fuel height"?
« Reply #4 on: September 06, 2018, 08:25:53 PM »
its a test of the fuel level in your carb bowl, and is very easy for PD carb bowls.
Fuel level is important.  too much and youre rich.  too little and youre lean.
http://forums.sohc4.net/index.php/topic,135470.0.html
http://forums.sohc4.net/index.php?topic=166447.0
« Last Edit: September 06, 2018, 08:27:35 PM by flybox1 »
Offline tommychains
« Reply #5 on: September 07, 2018, 04:22:15 AM »
hah very cool thanks
MicahDT
« Reply #6 on: September 07, 2018, 06:27:54 AM »
Plugs look like the engine is running too rich. I had the same problem when running rich. Mine was caused by float level as mentioned above.
