Author Topic: Which Piston Rings Do I Use with 300 Code Pistons?  (Read 1058 times)
Offline seebee750
  • Vintage Honda Restorations at Crows Cycle Works
  • CB750 K0,K4,.CB500 K0,K2,CL175 K0 '79 CBX
« on: September 06, 2018, 03:03:01 AM »
I have 4 NOS 300 Pistons. How do I know if I need one piece oil ring set like 13011-300-013 or the three piece oil ring set like 13011-300-024?
One piston has a 5 on it, two have 7s and one has a 9. Are these numbers important? Should these numbers be the same? All weigh 162 grams.
Thanks
« Last Edit: February 05, 2022, 04:36:26 AM by Glenn Stauffer »
They are not all the same!
Nothing is of great value until it is finished.
Re: Which Piston Rings Do I Use with 300 Code Pistons?
« Reply #1 on: September 06, 2018, 02:59:50 PM »
probably the standard ring set for the K-K2s
Manufacturer: Honda
OEM Part Number: 13011-300-013
Part: RING SET, PISTON (STD) (NIPPON) | Use up to Engine SN 2200000
https://www.partzilla.com/product/honda/13011-300-013
Offline seebee750
« Reply #2 on: September 24, 2018, 06:33:14 AM »
I guess what I really want to know is:
Will the three piece oil ring work on these pistons?
I have a set of 4 of the three piece oil ring type and only one set of rings with the single piece oil ring.
I don't want to spend money if I don't have to
« Last Edit: September 24, 2018, 08:24:01 AM by seebee750 »
« Reply #3 on: September 24, 2018, 10:02:02 AM »
QUANTITY   PART   CATEGORY   YOUR PRICE
1
RING SET (STD)
(13011-300-024) (replaces 13011-300-013)
Offline seebee750
« Reply #4 on: September 24, 2018, 10:29:27 AM »
Thank you Jerry. I feel less anxious when I see  the super-cession of part numbers in print for some reason.
