CR carbs have rails with slots for three of the bodies (one is fixed to just two positions), the fuel T also has a lot of latitude for whatever spacing you need. the throttle slide levers inside has long pins that self adapt to the new spacing, but you should check to see there's no binding. you are not going to need anything specific other than the screw-on adapters that need to match your rubber's ID
