Author Topic: Are 77 and 78 750 F motors really bad for gas mileage ?  (Read 2139 times)
« on: September 08, 2018, 05:42:39 PM »
 Mine is terrible,  fresh motor, run in now, not any better.
 I Been getting between 33 to 43 to a US gallon.
 With K motors I got 48 to 53.... and I am running the roundtops of those same motors. 110 mains
 What do you guys get.
« Last Edit: September 08, 2018, 05:48:20 PM by 754 »
Online Don R
Re: Are 77 and 78 750 F motors really bad for gas mileage ?
« Reply #1 on: September 08, 2018, 05:47:05 PM »
 My 76 F got awful mileage but it had tweaked floats and drilled jets. It was way better afterward we figured that out.
Online scottly
« Reply #2 on: September 08, 2018, 06:04:11 PM »
How did you mate up the roundtops to the larger F2/3 spigots?
« Reply #3 on: September 08, 2018, 06:36:45 PM »
I oiled them up and they popped on, fairly easy..
 I should check the clamps.
Offline BobR
« Reply #4 on: September 08, 2018, 06:49:27 PM »
 My F2 engine with earlier carbs (roundtops?) 115 mains seems to drink gas though I never measured my mileage. Bob
Reality is merely an illusion, albeit a very persistent one. Albert Einstein
 CB750K4(F2 engine)
« Reply #5 on: September 08, 2018, 07:34:14 PM »
My F3 with roundtops got low 40's generally, but I was always giving it the beans.  I might have made 50mpg on a long straight ride...so about the same as all my other cb750's
Online scottly
« Reply #6 on: September 08, 2018, 07:50:54 PM »
Frank has to give it "the beans" just to get it rolling. ;D That still doesn't explain the difference in mileage with the F motor; should be very near the same.
« Reply #7 on: September 08, 2018, 11:13:13 PM »
My K6 has always consumed around 0.6L/10km (40 MPG). Mixed speeds, city and highways. I think I have been down to 43 MPG riding really slow no twisting cruising around 70kph (44 mph). 836 with ported head and cam did not increase, except WOT.
Now with 1000cc and 32mm carbs mostly around 0.7L/10Km (34 MPG), this with some twisting. I have cruised closer to 0.6L/10km (40 MPG) when riding really slow which is very difficult.
Offline Bailgang
  • Scott
  • Indiana
« Reply #8 on: September 09, 2018, 05:12:31 AM »
My 77 F gets mid 30's to low 40 mpg but it's never been properly rebuilt either. The heads have new guides and valves and although the pistons have been re-ringed the pistons show their age and cyls could use at least a 1 size up overbore and pistons to match to get a good seal.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline 2wheels
« Reply #9 on: September 09, 2018, 05:54:29 AM »
Maybe the gearing, what sprockets do you have?
My F3 spins about 5000 rpm at 60 mph.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Online Don R
« Reply #10 on: September 09, 2018, 08:37:49 AM »
 I did go up a tooth on the front sprocket, the F turns more rpm at cruising speed. I'm thinking it went from 5200 to 4800 at indicated 75. That's just from memory but it seemed more relaxed on the interstate.
« Reply #11 on: September 13, 2018, 06:01:30 PM »
Just read in the PD 42 thread that an F3 uses 105 main, and a 77K uses 110.
 I run roundtops  and am probably rich with 110.. that or its my needles.
 But stil, a bit of a surprise the F3 runs a smaller jet..
« Reply #12 on: September 14, 2018, 12:31:36 AM »
The F3 had a high pressure muffler.  Likely the reason for the smaller main.
« Reply #13 on: September 14, 2018, 06:55:16 AM »
I was always pleased with 40mpg +/-
« Reply #14 on: September 14, 2018, 08:22:56 AM »
Red gets 35 to 38 mpg, but she has 657 carburetors.
Offline Skoti
« Reply #15 on: September 14, 2018, 12:41:42 PM »
My 1976 F1 used to get about 30 mpg (UK) until I renewed the needle jets and needles, now getting around 50 mpg but needs warmed up on the choke a fair bit when engine cold. Normally I'm cruising around 65mph two up.
(Gearing 60mph at 3500rpm)
Motorcycling is life, anything B4 or after is just waiting.
Honda CB750F1 1976
BMW R1150RT 2002
Norton Commando 850 Roadster 1974
Jawa 350 Blue Style 1992
