Author Topic: spark plug removal  (Read 2280 times)
Offline Bluewall
spark plug removal
« on: September 10, 2018, 12:48:12 PM »
I have been having a real problem removing the middle two spark plugs on my 73 750 k.  I can get one out and in but the #3 is giving me real problems.  Counting from right to left when sitting on the bike.  I am using a standard socket 3/4.  any advice?
73 750 , 79 CBX, 98 Valkyrie
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: spark plug removal
« Reply #1 on: September 10, 2018, 01:23:54 PM »
The spark plug socket should be 18mm, the original socket that came in the tool kit will work.
........Paul
Wear a helmet,the life you save may be your own.Ask me how I know.               CB650C,CB550F,GL1000,CB750A
Offline Bluewall
« Reply #2 on: September 10, 2018, 02:09:47 PM »
Thanks Paul
But unfortunately there was no tool kit when I bought the bike.
« Reply #3 on: September 10, 2018, 02:40:17 PM »
buy the an original honda spark plug tool...
« Reply #4 on: September 10, 2018, 02:48:08 PM »
There are small engine removal tools very cheap which may work. They look similar to the honda too.
Offline 05c50
  • 05c50
« Reply #5 on: September 10, 2018, 03:06:00 PM »
Thanks Paul
I use an 18mm socket that I bought from Sears.
..........Paul
Offline Bluewall
« Reply #6 on: September 10, 2018, 03:11:25 PM »
Thanks to all of you for the advice!!!!! ;)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #7 on: September 10, 2018, 03:29:27 PM »
I haven't checked my 750, but a 5/8 sparkplug wrench worked just fine on the 550.
« Reply #8 on: September 10, 2018, 05:27:30 PM »
that will only work on a 750 if you got Champions...
Bluewall, the clearance in the spark plug cavity varied over the years or from casting mold to casting mold...a standard 3/8 drive 18mm socket will not always work...the Honda toolkit socket will always work.  I have a 18mm socket that I found in one of my bikes that was ground thinner to fit.  Later I cleaned it up a bit in a lathe...so that can be another option
« Reply #9 on: September 10, 2018, 05:30:42 PM »
I got sparkplug wrench from vintagecb750, it works well.
Also there is a trick using rubber hose to start to thread the plug in.
« Reply #10 on: September 10, 2018, 05:49:50 PM »
Should look like this.. works really well with 1/4 socket welded in the end.
 Clearance  problem is at the valve cover.
 Use a short piece of hose on the porcelain part of your plug to start it, then you never strip one.
Install with socket, you take your chances..
Offline johans
    • corporate leather
« Reply #11 on: September 12, 2018, 12:34:15 PM »
I've been using this type for years and it saves a ton of grief on cars and bikes .  Old school is a piece of rubber tubing  .They are cheap also !
https://www.amazon.com/STEELMAN-08310R-Flexible-12-Inch-Starter/dp/B000IE5TSQ
« Last Edit: September 12, 2018, 12:46:22 PM by johans »
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
« Reply #12 on: September 12, 2018, 12:38:02 PM »
^^^ Frank, does it remind you of something?
« Reply #13 on: September 13, 2018, 05:12:24 PM »
Yeah coolant hoses,, snap together. Used them for air blast too..
« Reply #14 on: September 13, 2018, 09:41:57 PM »
CB750 stock plug tool is a must be used on 2-3 on my K6. Other tools are too thick since the cavities are tight. I have an old K1 head where even 1,4 are tight.
Offline robvangulik
  • Honda Fourever
« Reply #15 on: September 14, 2018, 02:43:36 PM »
We all agreed to start with #1 on the left, seen from the saddle! ;)
